Question about Bernina Sewing Machines
Bobbin winder doesn't spin, it sticks and nowit doesn't work at all. it starts to pick up speed without the bobbin on it though.
Bernina 1001
Trifect7
  • 57 Answers
SOURCE: Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Posted on Mar 02, 2008
SewTechWayne
  • 186 Answers
SOURCE: Bobbin winder won't spin
The two most common problems are that you either need a new bobbin tire, or just need to adjust the position of the winder a little closer to the hand wheel. Remove the top cover and you will see the winder assembly. Loosen the two screws that hold the assembly nudge it closer to the hand wheel side. If you move it too far the winder will constantly spin. Also, examine the rubber tire, it may have a flat spot on it in which case it needs to be replaced. If it is worn out you may not be able to tell just by looking at it.
These winders can be tricky to adjust but why not try?
Posted on Feb 06, 2009
bargainbox
  • 1388 Answers
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Posted on Sep 01, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
caroldon
  • 17130 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
I have the Bernina Artista 180. It is not recognizing when I turn the bobbin winder on. Any suggestions?
For a quick fix and until you can get your machine serviced, pick up a Sidewinder bobbin winder (check to make sure your bobbins will work since the larger Bernina bobbins may not). I purchased a Sidewinder a few years ago and use it all the time. Saves wear-n-tear on the machine but also lets you quickly wind multiple bobbins without having to unthread your machine. Most Sidewinders are battery operated, but mine also has an AC adaptor for electrical usage too.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Sep 24, 2017 | Bernina Sewing Machines
My Bernina bobbin will not spin to fill.
In the meantime, you can buy a stand-alone bobbin winder at JoAnn's or on the internet. It's great because you save wear-n-tear on your machine and you can wind several bobbins without unthreading your machine.
Apr 13, 2017 | Bernina Sewing Machines
My 1130 bobbin threader turns, but will not wind thread.
Check that the bobbin winder is snapped all the way over.
Sorry, unable to provide more help, but a standalone bobbin winder may be helpful. You can find one brand (called "Sidewinder") at sewing stores like JoAnn's or online for ~ $30. Just verify that your bobbins will work (some Singer bobbins do not), but I assume your machine is a Bernina. Even if your bobbin winder is repaired, this standalone bobbin winder will save wear and tear on your machine--also, makes it so-o-o-o much easier to wind a bobbin without first removing the thread from your machine.
Oct 10, 2016 | Sewing Machines
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
Bobbin on Bernina 807 won't wind?
Please follow the logic checks and possible corrections:
1. Check the winder shaft for a sticking or a stuck condition. If stuck or sticking, add a drop or two of mineral spirits to the winder shaft and the winder support bushing. This will generally release the winder shaft.
If the winder shaft becomes free wheeling, clean off excess solvent and apply a drop of Bernina machine oil which is typically a class 68 machine oil. You can also use a common white mineral sewing machine oil.
Do not use WD-40 or 3 in 1 oil!
If WD-40 had been used prior to the winder seizure then you'll know why....Removing sticky WD-40 residues requires further measures.
2. If only the rubber wheel has hardened, you will need to replace the winder hub with a new hub and replaceable winder ring or the entire winder can be replaced. There are some very good after-market parts available online.
3. If the winder parts are good and you are describing a condition where the hand-wheel will not release so that the machine drives while trying to wind a bobbin, this would requite another question and detailed answer... SewTechnical Home
Jan 25, 2015 | Bernina Sewing Machines
My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin winder shaft won't spin. LCD says bobbin winding.
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Bernina 145 Bobbin winding problem
If the winder is working without thread as it should you can rule out an electronic and motor issue. At this point it won't hurt to remove the two screws on top and lift your top cover off. Take a close look at your winder and see if there is any thread or anything wound around or blocking it. There are one or two screws that will adjust the eveness of your bobbinwinding but I don't think this is part of the problem (just a slight turn for that until the bobbin winds evenly). There is a spring beneith the winder that may have popped loose, check that but if the little arm snaps back and forth thats ok. The spring should be in the second tooth of the gear notches.
I hope this helps.
Jul 19, 2008 | Sewing Machines
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
