Question about Haan Fs20 Plus Steam Cleaning Floor Sanitizer
Haan FS-20 does not turn on - Haan Fs20 Plus Steam Cleaning Floor Sanitizer
Haan steam mop
The heating element may have failed.
Jul 25, 2016 | Haan SI-70 Steam Mop With Detachable...
Can you buy a water canister replacement?
Perhaps you can , but not thru this website .
Sep 05, 2015 | Haan Si-35w Slim&light Floor Steamer
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
B&s engine on mower turned upside down, won't start now.
Take the spark plug out, turn ignition key or pull rope until the engine turns over several times. Let it sit for about 5 or 10 minutes and repeat. Replace the spark plug with a new one. Make sure that your crankcase is not over filled or under filled with oil, and make sure that there is plenty of gasoline in the tank. Make sure that gasoline cap and oil cap are on "securely". Now try to re-start. (The engine may smoke for a while, but it should clear up in a few minutes).
Nov 27, 2013 | Craftsman 16-gal 6.5-peak hp Wet/Dry Vac...
How do i remove the hose from the haan gs 60
Look for a push-in button on the machine where the hose attaches to it. Also check that there may be a twist off connection with 2 pins on the machine that connect to the holes in the metal end of the hose...either is possible..Good luck!
Dec 28, 2012 | Haan GS-60 Steam Station Garment & Home...
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
Haan Fs20 Plus Steam Cleaning Floor Sanitizer Logo
37 people viewed this question
Top Haan Vacuums Experts
ray gallant
Tom Chichester
Are you a Haan Vacuum Expert? Answer questions, earn points and help others
