Question about Microwave Ovens
MY AQUAGUARD CLASSIC WATER PURIFIER IS NOT FUNCTIONING PROPERLY.
Light is not going on green it is ******* back to red
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
How to turn the oven light off on my Kenmore Elite Electric stove model790.
You should have either a shorted out door switch or a shorted out light switch on the control panel.
Removing either one and unplugging it should show you which one is the problem.
God bless your efforts.
Nov 30, 2016 | Kenmore Microwave Ovens
Repair Manual of Aqua Guard Inova water purifier
hi,the water from my aquagaurd inova comes for two minutes and stop and green light goes off
Aug 27, 2011 | Microwave Ovens
I have the west bend 56870 the prgramable coffee pot and I never got a manual with it and I have no idea what the red light or yellow light is or even how it works send me instructions and itll be well...
Customarilym RED represents there is power and the ubit is on. Yellow/amber would indicate ubit is preheating the water in the resevoir and once heated properly, a green light should appear. Check all around the unit for a master on/off switch. Make sure it is on. Now, The timer is your actual start/stop controls. It should start at the time you set for brew and shut off at a predetermined time so it's not left to burn dry.. Sometimes, or more often than not this off setting is regulated by a temp sensor or timer factory set. I don't have a manual so I hope this helps. Remember, the setting you make is the setting it starts doing anything. Good Luck. I'm sure yoou will appreciate it once you get it to fire up. -Ned_
Nov 16, 2010 | Microwave Ovens
Eureka Forbes Infinity Water Purifier not working. Its blinking a red light and then not coming on.Its only 3 months old.
contact the manufacturer.and see if they have a solution, or if it is a warranty problem.At only 3 months I would think they should be able to help you
Nov 07, 2010 | Microwave Ovens
HI, The water from my Aqua Guard Gold Nova does not come out but the light and the sound switches on. So someone told me that the filter might have to be cleaned or changed. Please tell me how to...
I have Aquaguard Nova from Eureka Forbes. Presently, on switching-on the water there is only beep sound for some time and then it stops. This is no music. What can be the problem? Is the water still filtered properly?
Aug 24, 2010 | Microwave Ovens
We bought philips water purifier three days back.... trying to contact people ...to install the water purifier .... plz send somebody!!!!!!!!!!! my add- 172 /c vikram path. MCTE MHOW dist...
You are on FIXYA we cannot send people out to install your water purifier. This has to be done by the supplier you bought it from Alternatively look in the phone book under water purifiers and engage an indepenedent installer to do it for you.
Please rate my help++++Thanks for using FIXYA
Jul 29, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
