Question about Apple iPod Audio Players & Recorders
Apple ipod 2generation a1051 shows sad face icon
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Because you're a bad person
Posted on Apr 24, 2014
  • 13433 Answers
SOURCE: ipod shows sad face and folders
the sad face means there is a software / hardware side fault witch needs service.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
If they dont work you will need to send the ipod in for service.
Posted on Apr 19, 2008
SOURCE: iPod does not charge
Search for 'The iPod battery Unplugged' it will probably help you diagnose the problem cheaper than apple will
Posted on Jul 17, 2008
SOURCE: my ipod shows a sad face
Sad Face is almost always an indicator of a broken HD.
new ipod hard drive
http://www.ipodrefresh.com
Posted on Aug 14, 2008
  • 102 Answers
SOURCE: 30 gb ipod has sad face and low battery icons
could be bad charger or time to replace the battery. lots of places sell new ipod batteries.
does it work if you leave it plugged into your computer for a few hours? if it does not then its a bad abttery.
Posted on Sep 23, 2009
  • 105 Answers
SOURCE: my apple 30GB has sad face /www.apple.com/support/ipod
Hi, you may want to try reset your iPod: 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) 2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Regards, Peter
Posted on Aug 07, 2010
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
Tip
How to resolve Sad face icon issue for click wheel iPod's
If you are seeing a sad face Icon on your click wheel iPod, you may be able to resolve the issue by following the instructions below.
What you will need:
iPod
USB cable
USB power apple iPod compatible wall adapter
The latest version of iTunes installed on your computer
The process remains the same for Mac and PC
First you will need to force your iPod into disk mode. To do this you will need to reset the iPod by pressing and holding both the menu and center buttons. Continue to do this for at least ten seconds or until the apple icon appears. (Note: You may only see a blip on the screen, continue to the next step. Keep in mind though that you may need to repeat this process once to twice to force the iPod out of the sad face status.)
As soon as you do see the apple icon, remove your fingers and switch to holding both the play and center buttons. Keep holding those until you see a check mark appear on the screen, below it will say Ok to disconnect. At this point your iPod will be in Disk mode.
Next open ITunes on your computer and plug in the USB cable to one of the ports on your computer. Now you will connect your iPod to the USB cable. In the left hand column of iTunes you will see your iPod icon; go ahead and click on that icon. In the resulting page you will see the iPod summary. Within this page you will see a Restore button. Click on that button and follow any on screen instructions. Allow the restore to complete fully. When it has you will see that the screen of your iPod will have changed. It will now be displaying a picture of a power adapter being plugged into a standard wall outlet.
Disconnect the iPod from the USB cable and connect it to the wall adapter. You almost instantly notice the screen will show a status bar that is showing that it is actually being restored to factory settings. Once that has finished the screen will light up and work as it did before the sad face icon incident.
Just as a note: If you have dropped your iPod many times, submerged it in water, or any other extreme damage has occurred; this may not work for you.
Mini Tip:
If it has been submerged in water though, you can place the iPod in a full bowl of dry rice. Completely cover and leave for at least 24 hours. I personally recommend 48 hours for best results. It is not a guaranteed resolution, but has worked for me in the past.
on Feb 03, 2010 | Audio Players & Recorders
SAD FACE ICON
In most cases, the sad iPod icon indicates a hardware issue. If you are able to force iPod into Disk Mode, then it may not be a hardware issue, and you should try to restore your iPod with the latest software.
To force ipod into Disk mode http://support.apple.com/kb/HT1363?viewlocale=en_US
To restore ipod http://support.apple.com/kb/HT1339?viewlocale=en_US
Jul 19, 2009 | Apple iPod nano
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Ipod showing sad face
There is a free video on the Sad Face icon issue at the following web address. I hope that it is very helpful to you.
http://fixyouripod.weebly.com/
It is the first video on the page, just scroll down a little bit. :)
May 08, 2009 | Apple iPod shuffle MP3 Player
The sad ipod comes up then I reset it and the apple icon comes up then it goes back the sad ipod
i have th same prob..
it turns on, starts clicking, then shows frowny face ipod, then a website is shown, then turns off........
helpppp
how did urs brake?!?
Oct 02, 2008 | Audio Players & Recorders
Ipod shows sad face and folders
Apr 19, 2008 | Apple iPod 4th Generation MP3 Player
My ipod shows a sad face
IM SAD TO SAY BUT YOUR IPODS HARDDRIVE MAY HAVE CRASHED
Mar 18, 2008 | Apple iPod nano
Hopefully your ipod is still under warranty, because this is indicative of a hardware problem.
You could try to force it into disk mode and do a restore, if that doesn't work then it needs to be sent in for repair.
http://docs.info.apple.com/article.html?artnum=61771
Jan 25, 2008 | Apple iPod 4th Generation MP3 Player
48 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
