Question about HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer
Pick motor stalled
Won't print. says pick motor stall
2 Suggested Answers
djgillstudio
  • 107 Answers
SOURCE: Pick motor stalled
hello, did you recently have a paper jam, if so, turn machine around, take off duplex unit if its installed, if not remove the back cover, now if your looking at rear of machine, there are several small gears, check that there is no paper debris stuck in there, its hard to really gage if paper is in gears. the grey roller with the white gear should move freely to a point, if it does not move at all, then yes something is stuck. now if it does move freely, then go ahead and put back piece on, lift up front cover as if you where going to replace printheads, move the carriage to the left, look into machine from the left side, and check to see if there is any paper bunched up in that area on the right. if nothing go ahead and close and allow machine to cycle or power up. if the machine has gear crunching noise, turn off, and take to repair. its a little tricky to pull apart, you will need 2 type of torq bits to use.
Posted on Sep 27, 2010
How do I fix "pick motor stalled?
You have to open it to see what us actually stalling or jamming it first, and try to restart and Resset your device..
Oct 05, 2014 | HP Officejet Pro 8600
How o I fix the "pick motor stalled"?
If printer within warranty period then contact customer service....it is faulty!
if not then reset by un plugging at mains for 30seconds then plug back in, turn on and wait till warm up and silent.......has it cleared error? If so then print test sheet!
hopefully good to go!
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
.Engine stalls, won't idle, bucks at 3700rpm
Sounds like mass airflow sensor to me or your timing jumped. Probably high miles too, eh? Could possibly be voltage regulator but I highly doubt it.
Jan 16, 2013 | 2001 Ford Explorer
1980 Suzuki Gs450L won't start. I stalled out pretty bad in 4th gear and it won't start back up after. Bike won't even crank over, just makes a clicking noise. Any ideas?
pull the plugs then crank motor you may find one cylinder full of gas and that will keep it from cranking, if it cranks without the plugs allow it to dry for a bit , make sure plugs are dry then install and hopefully GO!
Jul 04, 2012 | Suzuki Motorcycles
6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Sep 16, 2009 | Boating
Motor stalls when driving then starts and stalls right away.
Replace the distributor's magnetic pickup located inside the distributor surrounding the distributor shaft, the only other thing thankfully on this ignition system if memory serves me on the f 150 straight six 300 cu inch is the dura spark ignition control box, of course do the obvious tune up parts replacement dist.cap rotor,plug , sparkplugs before spending the $40.00 - $50.00 bucks on the dist.. pick up, you may have a weak a fuel pump check for adequate fuel pressure at carb 7 - 10 lbs.
Aug 06, 2009 | Ford F-150 Cars & Trucks
Oil pressure drops to nothing and engine stalls
it has worn rod bearings . motor needs rebuild
Jul 08, 2009 | 1989 Chrysler LeBaron
93 s10 2.8 wants to stall out after restart
You probably have a clogged fuel filter. There should be an inline fuel filter between the gas tank and motor, replace that and your good to go. I have the same problem with my c10 pick up.
Dec 28, 2008 | 1985 Chevrolet Chevy
HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer Logo
Seeker5211
Seeker5211
