Techwood receiver plr85
DVD video1&2 tape / all inputs are not working but tuner does how do I resolve this issue to get my inputs working?
4 Suggested Answers
SOURCE: techwood home theater remote code model #plr85
try 212, i have the same exact thing. I used the auto search remote codes method and it found and works on that code...
Posted on Jan 25, 2009
  • 1348 Answers
SOURCE: my techwood plr85 keeps saying PROTECT every time i turn it on.
disconnect the speakers one at a time and see if the protect goes off.there may be shorted speaker leads on the back of the amp or a speaker.a common thing is to hit the wires with a vacuum or furniture.once i saw someone hang a picture and put a nail right thru one of the wires that were installed when the home was built.if all speakers are disconnected and the protect is still on,then there is a dc fault in the amp and it needs to be looked at.the most common cause is a blown output transistor or ic
Posted on Jun 13, 2009
SOURCE: Techwood 400 watt Stereo Receiver PLR85
the protect light keep comming on
Posted on Aug 21, 2010
I can watch regular channels. But when I try to watch a dvd or vhs tape it says not connected.And when I switch the input to video 1 it still wont work ?
Your tuner is working but, unfortunately, your input circuits on set are fubar. Cheapest way to resolve issue is to get an rf modulator, connect to external source, and feed that rf signal to channel 3 or 4 of your tuner.
Sep 28, 2016 | Televison & Video
How to rechannel techwood tv wtp4210 from uk to phillipines pls, help
Techwood, is made by vestel Technologies for AO
TV How To Guides
unsure if you are trying for basic terrestrial transmissions (plugged into on-board Tuner) if so follow the guide above.
if you are trying to attach a digital tuner, that should just plug into the HDMI port and should work straight away.
if you are trying something else, or the above is not working please let us know, and I will try to resolve.
Feb 01, 2016 | Televison & Video
Techwood Codes
0022,0000,9999. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Check this link too. http://electronicshelponline.blogspot.com/
Oct 22, 2013 | Televison & Video
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
Hi, my Nakamichi Av 10 receiver tuner and the video AUX section is dead and does not work except for the Tape in
I am facing the same issue All Analog inputs except for Tape in does not work and the tuner does not work on my Nak AV-10
Jun 03, 2010 | Nakamichi AV-10 Receiver
I have a Amp,CD player,Tuner,and DVD player. no a tape deck.how can i conect all, with out a tape deck through eqeualizer.
You can connect the EQ on the tape in/output of your amplifier. Tape out (or monitor out) to the input of the EQ and tape in to the output of the EQ.
Listen to the tuner and than switch to the tape input, the tuner input will be still active. But in the tape "mode" your EQ will be active too.
Regards,
Gerard
Jan 10, 2010 | Yamaha EQ-70 Home Equalizer
Function Selector Bypasses Input Sources
Hopefully this post isn't too late... That receiver has the ability to disable certain inputs. The easiest thing to try is to do a factory reset.
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Unfortunately, this clears out all of the other settings on your unit. It should, however, re-enable the inputs.
Let me know if this helps!
Dec 28, 2008 | Sony STR-DA90ESG
Techwood home theater remote code model #plr85
Feb 27, 2008 | Audio Players & Recorders
I have a Techwood PLR85 spearkers will not play, have replaced bus fuses 6v&7v fuses keep blowing out and still nothing
Feb 20, 2008 | Audio Players & Recorders
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
22 people viewed this question
 Grubhead
Grubhead
