Question about Creative Labs Audio Players & Recorders
Hi, DAPHD0019 driver NOT FOUND
TRIED a lot of things, all usb ports, media 10, $13.00 tech support,reboot,reformat, uninstall & reinstall everything. player is well charged, works ok on other computers, but this one. Computer sounds off when I turn player off & on.
Please Help
  Thanks
        Rob
bogus
SOURCE: WINDOWS MEDIA PLAYER WONT DETECT DEVICE
i had a similar problem (would not load driver) and was able to solve with the following: 1. install version 10 or greater of windows media player. 2. in Device Manager (hardware tab on System in Control Panel) right click the ? Samsung YP-T7J and pick update driver 3. Select No, not this time, Next> 4. Install from a list...., Next> 5. Don't search, I will choose.., Next> 6. Select Portable Devices, Next> 7. Select MTP Device, Next> 8. The drivers are copied and the device is recognized. There are other prompts depending on your media player config, but only pertains to how the device is handled. jlw.
Posted on Mar 20, 2007
Jessamole
SOURCE: Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Posted on May 09, 2007
  • 3 Answers
SOURCE: My computer wont detect my player
For my Sansa clip, if i put it on hold and press the center button as I plug it in, my computer will recognize it.
Posted on Nov 26, 2007
  • 476 Answers
SOURCE: Player cannot get connected to computer-Philips GoGear SA3115
Install and run the Philips Device Manager software from the product CD.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and repair the firmware.
Posted on Apr 02, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 23, 2008
Usb ports do not work. Windows does not recognize them.
IT may be time for a new systemboard. This is a common recall issue with the dV6000. If you wanted to be sure, you could reinstall windows just to verify everything is okay there.
Jan 06, 2011 | HP Pavilion dv6000 Motherboard
Presario s4000v
plz try to reinstall your sound drivers
Jan 14, 2009 | HP Presario S4000V (Open Box) (P8655P3) PC...
XBOX 360 Wireless Controller PC Connection Problem
WARNING: try at your own risk!
I kind of fixed it. The problem appears to be with the USB controller - specifically, my mouse (a Razer Copperhead) and the XBOX 360 wireless receiver. A lot of work went into the solution, but I essentially ended up uninstalling and unplugging all of my USB devices (you can uninstall them using device manager in System Properties>>Hardware within Control Panel. Look for Universal Serial Bus and uninstall everything in that category). Reboot. Then, I first plugged in the device in question (my 360 receiver). Afterwards, I one by one plugged in each item until I found the one conflicting with the receiver (my mouse). After that, I uninstalled all devices again and next uninstalled the drivers for the conflicting device (my mouse in this case) and rebooted again. After this, I tried several times to uninstall and reinstall the mouse and various USB devices until finally it worked (sort of).
I call this a partial solution because now I appear to have the opposite problem. My mouse seems to be conflicting with another device (probably the 360 receiver). My mouse refresh rate is very choppy. The good news (for me) is that I can uninstall the USB controller for the mouse, reboot, and both the 360 controller and the mouse will work fine... that is until shut down. Then I have to uninstall the mouse controller and reboot again. Needless to say, I keep my computer on more than usual now.
Nov 25, 2008 | Microsoft MS Xbox 360 Common Controller...
The computer no longer recognizes the mp3 player when it is connected thru the usb port6
I had the same problem. Reinstalling Windows Media Player didn't help; nor did reinstalling the Creative drivers.
But this worked... in Device Manager I uninstalled everything under Universal Serial Bus controllers, rebooted and let Windows reinstall the USB drivers. Had to reinstall my mouse software too, but the Zen is now back to normal.
Hope this helps someone.
Sep 06, 2008 | Creative Labs Zen V MP3 Player
USB ports no longer working
After all done,
Did you think of replacing motherboard?
Feb 17, 2008 | Computers & Internet
Connection issue
reboot the pc, also try a different usb port.
Dec 11, 2007 | Computers & Internet
Zen vision:M and vista don't work together
It might be a firmware problem. Creative's website should have the latest firmware which you can flash to the unit, then reinstall the drivers again using the latest driver from the web site.
Dec 02, 2007 | Creative Labs ZEN Vision:M Digital Media...
370 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
