Question about Garmin DC 40 GPS Dog Tracking Collar
Dc 40 wont light up
Dc 40 want light up change battery still want light up
Unit wont start,only clicking noise
Battery is no good/not charged.
Oct 25, 2015 | Garden
DOES THE FORD TAURUS HAVE A VOLTAGE REGULATOR
Every car ever made has a voltage regulator
The alternator is just that-- AC Current that is rectified
to DC-- to run the car & charge the battery
Just about every car for the last 40 years has the
regulator inside the alt
How it is controlled varies from manufacture,make,
model,year,etc
You can not charge a defective battery
You may have external issues that provide
regulator control,even a bad ignition sw on
some cars,or module control of regulator
Need a wiring diagram & a good amount of
knowledge to resolve your current problem
Jan 24, 2013 | 2001 Ford Taurus
My dc40 collar wont pick up signal even when i place it next to my astro 320 ive only used it three times i was hunting the other night and it lost signal and i cant get it to work anyone know what the...
We have had the same trouble with one of our DC40 collars, its been doing it pretty much since day1 when we got it but now it wont pick up communication at al. We have changed the battery and updated it as well, The light on the collar stays on, it doesnt flash when its on like its supposed to. Any ideas on ficing the problem?
Jul 20, 2012 | Garmin DC 40 GPS Dog Tracking Collar
My CAssette reverse airconditioner wont respond to remote. Changed batteries worked 2 times then stopped
It's transmission error. Please remove batteries from remote.Remove power for a/c. Remove Dc wires plugged into indoor display sensor. Wait for 5 minutes. Now replug DC wires. Reset batteries in remote. Power on, Check now.
If still problem, check remote thr' mobile camera and press any button in remote. If you could see thr' mobile camera the ultra light in remote, it's o.k. Then you have to replace PCB of indoor. If no ultra light, replace remote.Thanks.
Feb 02, 2011 | Heating & Cooling
I have a Toshiba Laptop, and it will not turn on (it is plugged in and the battery wont charge either). I tried turning the laptop on while it was plugged into the wall and with the battery and I only get...
hi,
here is what you can do...
I have a video clip below (courtesy of youtube) to guide you on how to diagnose your laptop.
The video explains what you can do.
Hope this helps your problem.
Don't forget to rate me. Thanks...
Regards,
John
Jan 11, 2011 | Toshiba Satellite A135-S4527 Notebook
My power button on my rog is showing orange the fan is running when I turn the laptop on but nothing else is the orange light telling me that the hard drive is bad, the memory needs to be changed, or is it...
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the process.You also change the ac adapter for ensure,about your adapter ok or not.
Hope it help you.
Jan 06, 2011 | Gateway 450ROG Notebook
The light goes on, it seems to start...then light goes off and then nothing. Optiarc DVD RW AD-7560A ATA Device HP Pavillion Vista
Remove the dc battery, and unplug the dc adapter.You will hold or press the power button for 40 seconds.Now you will get positive result,when you plug the adapter to your laptop and the Battery also.Almost 80% laptop can solve for this problem through the proceses.
Hope it help you.
Dec 31, 2010 | HP Computers & Internet
2005 magnum esp/bas and engine light on
you need to see what the eng lite for if there is a trans codes usually the pcm wont let the speed go over 40 stays in safe mode untill you fix the problem or change the sensor,for the esp you need to chage the esp sensor and recalibrate by the dealer
Jul 20, 2009 | 2005 Dodge Magnum
Garmin DC 40 GPS Dog Tracking Collar Logo
23 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
