Question about Nikon COOLPIX Cameras
Nikon flashing green arrow
Flashing green arrow
How do i change from remote ttl on my nikon sb800.
Press the Menu button. Scroll to the Custom Setting Menu. Scroll to "e Bracketing/flash". Right arrow and scroll down to "e3 Flash cntrl for built-in flash" and push the center button. You now have access to the TTL, Manual, Repeating flash and Commander modes. Right arrow on CMD and a menu will appear that allows you to set up the built in flash and the external flash groups.
Aug 15, 2013 | Nikon Speedlight SB-800 TTL Flash
Tip
Flashing green death
My Nikon D70 quit working and would only flash a green light. I contacted Nikon and they fixed it, no charge. I was very happy with Nikon for the free repair! If you have this problem, go to the Nikon website and do a search for flashing green light. They cover this problem as a defect and did not ask for any proof of purchase or anything. Very smooth and easy. Thank you Nikon!!!
on Oct 15, 2007 | Nikon D70s Digital Camera
Flashing green light
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
Jun 02, 2013 | Nikon COOLPIX P510 16.1 MP CMOS Digital...
Hello, I can't turn off the flash on my nikon coolpix L20. Can anyone help me out?
In the shooting mode, press up-arrow on the multiselector (marked with a lightning bolt). Select the no-flash icon (lightning bolt in a circle with a slash through it), then press OK.
Oct 31, 2010 | Nikon COOLPIX L20 Digital Camera
How do I change resolution on my nikon l18
Press the shooting mode button in shooting mode to display the shooting mode menu and set the shooting menu to Auto mode (the green camera). Press MENU to display the shooting menu. Use the arrows to select "Image mode."
Aug 04, 2010 | Nikon COOLPIX L18 Digital Camera
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
MY NIKON D50 SCREEN HAS THE WHITE AREAS OF PICTURES FLASH BLACK AND WHITE
Jul 21, 2009 | Nikon D50 Digital Camera
Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
May 29, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Nikon d40x flashing when viewing photos in camera
Pull up the photo in image view, then use the up arrow until the flashing stops.
Dec 08, 2008 | Nikon D40x Digital Camera
NIKON D 40 CAMERA HAS BLACK FLASHING SPOT IN THE LCD
Try pressing the up or down arrow when you see the flashing spot. It may be that you have accidentally activated the highlight indicator.
Feb 13, 2008 | Nikon COOLPIX L10 Digital Camera
Cameras Logo
19 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
