Mitsubishi SRC502ZL air con split need circuit board pt numb RPC505A601 where in Adel can i get one
2 Suggested Answers
koolbreezes
  • 540 Answers
SOURCE: KELVINATOR KSR20C
One might think so, YES! look on one of the door panels that you can remove! Thank-you-very-much!
Posted on Aug 23, 2008
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
My REMOTE CONTROL IS NOT WORKING I HAVE TO SWITCH IT OFF FROM THE MAIN HOW CAN I GET A RELACEMENT IT IS AN LG SPLIT SYSTEM AIR CON?
First try to change the batteries before replacing the remote control. Buy replacement from SEARS or any LG suppliers. Sometimes the problem is in the control board circuit due to condensation.
Sep 02, 2011 | LG Heating & Cooling
Mitsubishi air con msza24yv. when we turn it on to the heating mode the operation light keeps blinking and nothing happens
Wait 5 mins after turning the unit on to make sure it is not on a pre heat, and if problem is still there check fault code on controller
Jul 04, 2011 | Mitsubishi MSZ-A24NA Split System Air...
An lg nep plasma split system air con. when its turned on it comes on for about 3 seconds before turning it self off?
go to your main switch board turn the ac unit circuit braker of for a minute then turn back on. it pretty much just opens its fins then beeps then closers?
Nov 09, 2010 | Heating & Cooling
What sq m is covered by a MSZGA71KIT split air con?
That should cool up to a 60 metre squared room. I would have the room measured up by a professional and they will also calculate heat loss and recommend the right unit for the job.
Hope this helps I take the time to help you so please rate me
Dec 13, 2009 | Mitsubishi MSZ-A15NA Split System Air...
Pipes frozen on outside of unit, inside unit does not work
sounds like the compressor relay is stuck in the 'on' position .... hence the compressor will not turn off .... to fix it you will need to turn off the main power (unplug) and take off the front panel then look at the circuit board normally the largest relay on the board is the compressor relay ... sometimes you can snap off the cover or break it off at times and clean the contacts ,give it a little spray with some contact cleaner or lub like wd 40 and that should be it .... alternative to this is just changing the circuit board all together ....
May 19, 2009 | Mitsubishi Heating & Cooling
LG S36AHP-UD7 Split Air Con. won't turn on.
Generally when an ac trips the main breaker and the breaker its self isn't bad, the compressor is going bad or is bad. To check you will need to do an ohms test on the compressor. If you get a reading of less than infinite, then the compressor is bad. You will need to test every lead going to the compressor which is usually 3 unless you have a crank house heater installed but they are not typical on a small unit. If the compressor has gone bad it is possible the it took the board out as well.
Mar 31, 2009 | LG Heating & Cooling
KELVINATOR KSR20C
Aug 02, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Sep 10, 2007 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
