Question about Maxtor Computers & Internet
Maxtor drive no longer recognized
I cannot get to my backup files
peepnklown
  • 175 Answers
SOURCE: Transferring Files to Maxtor backup drive
Find your MAXTOR model and you can download guides (basically, the manual and it will show you step by step instructions).
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Installation_Assistance&vgnextoid=dce3b27d0434e010VgnVCM100000dd04090aRCRD
Posted on Nov 12, 2007
SOURCE: Maxtor 3200 backup drive not recognized in my computer to access
Posted on Dec 31, 2008
  • 14 Answers
SOURCE: Maxtor won't allow me to delete files that are no longer on my XP
You might not be able to see the hidden files... If this is the case you can enable XP in order to view them as follows.....
Windows XP and Windows 2003
To enable the viewing of Hidden files follow these steps:
  1. Close all programs so that you are at your desktop.
  2. Double-click on the My Computer icon.
  3. Select the Tools menu and click Folder Options.
  4. After the new window appears select the View tab.
  5. Put a checkmark in the checkbox labeled Display the contents of system folders.
  6. Under the Hidden files and folders section select the radio button labeled Show hidden files and folders.
  7. Remove the checkmark from the checkbox labeled Hide file extensions for known file types.
  8. Remove the checkmark from the checkbox labeled Hide protected operating system files.
  9. Press the Apply button and then the OK button and shutdown My Computer.
  10. Now your computer is configured to show all hidden files.
Posted on Jan 08, 2009
SOURCE: Maxtor External Hard Drive not recognized
you can find a program on the maxtor/seagate site maybe you can fix this with that..
Gr Rich
  • 6 Answers
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Posted on Feb 14, 2009
I have a Maxtor onetouch 4. I want to use it as an external hard drive. Windows explorer recognizes it but when I try to copy files to it, it says the drive is write protected. I down loaded the Maxtor...
That's because the software it comes with unlocks the drive to do backups. You should be able to format the drive in windows and then it should work fine for your purposes.
Right Click the Drive, Select Format, give it a volume name if you want and select quick format. Leave everything else default.
Comment back if you have any questions
Sep 11, 2011 | Maxtor OneTouch III Mini Edition 120GB...
How do I start making my Maxtor start backing yp
Do you want to create a backup file or do you want to keep your original files saved on your Maxtor? If you want to create a backup file for the files on your computer, type "ntbackup" in the "Run", the backup wizard will automatically start and click "next" > "backup fies and settings" > "Let me choose what to backup" and then select the files and folders you want to backup by click the snap-ins (+ signs) and check mark the files or folders and again "next". In the option "choose a place to save your backup" click "browse" (if you are prompted that the drive A:\ is empty click "cancel") locate your Maxtor directory, click "Ok" and name the backup file something you like, click "next", the backup process will begin with the status monitor. It may take several minutes depending on the files you've selected. That's all. If you wanna restore the backup files, just double click the backup file you've saved and when the wizard opens, select "restore files and settings" and follow the onscreen instructions.
Good luck.
Thanks for using FixYa.
Jun 21, 2010 | Computers & Internet
My computer no longer recognizes the Maxtor one
Windows may be recognizing the drive but not assigning a drive letter for some reason. you may need to go to disk management2_bing.gif and look for the drive there.
to do so go to control panel/administrative tools/computer management
once computer management is up find disk management, inside you will find all the drives that are connected to your computer, you should find your drive, If you do not then the drive may be bad or you are having usb issues.
If the drive is there but does not have a drive letter assigned to it, this may be because another drive has taken the letter normally assigned to it, you will need to right click on it and say "assign drive letter"
Let me know if this helps.
Mar 17, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Maxtor Basics 500GB Hard Drive MXT3002 The Backup location cannot be found or is not valid. Review your Backup Settings and check your Hardware Configuration 0x81000006. File Backup could not start for the...
is your drive normally detectable in system? if yes [it has a letter asigned] run command prompt and cd /D <drive letter> chkdsk /r if asks to unmount say yes then reinstall backup program
Sep 22, 2009 | Maxtor Computers & Internet
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Gr Rich
Jan 08, 2009 | Maxtor OneTouch III 500 GB Hard Drive
Onetouch 4 internal error 8211
That error occurs when the 3 Quickbooks files don't have the same date. I'm not sure how they get out of synch, but if you check the dates of the files on your Maxtor backup, you'll find they are different.
The easy solution is to delete the files from your Maxtor backup, and then immediately do another backup. Maxtor will copy the current files over and you'll be all set.
Oct 26, 2008 | Maxtor Hard Drive
Computer not recognizing my Maxtor hard drive
Andrew, That Maxtor drive sounds like it has finally died on you and being just an 80 gig drive means its really old. The systems failure to read the drive as your booting up is what's causing the long boot delay as the system will see the controller board of the drive, but your spindle motor on that drive is most likely dead and there fore you will not be able to access or read any of your data stored on that drive. Hope you had backups of important files.
Apr 15, 2017 | Maxtor OneTouch A01B080 80 GB Hard Drive
BACKUP
i think if you just start the maxtor manager and clik on back up, you should be able to select which files or drive you want to back up . hope that helps
Sep 23, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Sep 16, 2008 | Maxtor Hard Drive
Computers & Internet Logo
21 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
