Question about Electronics - Others
Emtec z1467 When I plug the usb drive in my computer,nothing happens. The computer does not see the drive,there is no removable partition. I have tried it with other ports,the red led lights up but it doesen't work.
kgjsm397
  • 105 Answers
SOURCE: nothing happends when I plug my drive into my PC's
Surely you have to install driver first because windows does not have it in cache. If you don't have go manufacturer site
Posted on Apr 17, 2008
falseadress
  • 45 Answers
SOURCE: Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Posted on Jun 01, 2008
SOURCE: Portable Hard Drive will not respond / install
how many wattage had your computer? you need to upgrade your power supply.you need also to check your bios setup on usb port
Posted on Oct 03, 2008
  • 77 Answers
SOURCE: cant remove write protect
Download this small file:
http://www.kellys-korner-xp.com/regs_edits/writeenable.reg
Save the file on your desktop. Then double click the writeenable.reg file and click on Yes when Windows asks if yo u want to write to registry.
That;s it. Now you can try to create a new folder on your usb drive and it should be created. That means it's now normal.
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
Geekman
  • 32281 Answers
SOURCE: Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
Posted on May 05, 2009
How to remove password?
Take a hammer and smash it. Then buy a new one.
Nov 09, 2013 | EMTEC Magnetics Group Electronics - Others
Install emtec flash drive usb
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Jul 27, 2013 | Electronics - Others
You need to format the disk in drive F: before you can use it. Disk is full of information.
have you recently formatted your computer installing a new operating system.while installing it you have made attemps to remove the partition and then you have created a new partition.nothing you can do now exept formatting it.ok
Apr 20, 2012 | Seagate USB 2.0 External - 160GB - 5400rpm...
My Emtec animal USB flash drive isn't showing up on my computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Jan 10, 2012 | Electronics - Others
It does not read when plugged in, I had problems with it when for no reason it went from MY BOOK to Drive after several hours of trying to fix it, I eventually got into my music then I went to safely...
Turn on your computer, plug in your My Book external hard drive (double check that the power is properly plugged into the wall and the hard drive), If nothing happens then right-click My Computer (or labeled just as Computer in Windows Vista or Windows 7), Choose Manage, Choose Storage, Choose Disc Management, towards the bottom of the window you will see Disc0, 1, 2, & so on. Are any of them colored with a Black bar across the top and labeled as Unallocated Space? If so, then right-click in that box and choose create simple volume and format in NTFS. If you don't see your hard drive listed in this window, or if you are unable to partition and format the drive, then most likely your hard drive isn't any good anymore. If it's under warranty, then return it for a new one.
Jun 15, 2010 | Western Digital My Book Essential 1TB...
Emtec mp3 player won't turn on
This is a simple flash Mp3 player, I went on the manufacturers website..they do not have any firmware for either the C215 or the C210. So if you installed firmware to it, its possibly you installed the incorrect software on the unit. Most firmware restores the actual information such as the menu and playback options for your music. The biggest issue you have to look at is the device not turning on when its disconnected from the computer, I would check the battery..and then hold in the Play button for about 5 seconds, if nothing comes up, then your probably right, you just have a flash drive. You might contact the manufacturer and see if they can email you the firmware (if available).
Product details:
http://www.emtec-international.com/en/driver.php?categorie=AVNOM&gamme=LECTEURS%20MP3&ss_gamme=C210
Email Form for EMTEC (didnt see a phone number)
http://www.emtec-international.com/en/assistance.php?categorie=DEFAU
Oct 15, 2008 | EMTEC Magnetics Group C215 MP3 Player
SimpleDrive external USB Disk Drive
You may not see any icon on desktop but should see "found new hardware" at the bottom right by the time. Right click My Computer and click Manage. Under Storage click Disk Management. You should find your drive here. If its a new drive, no letter may be assigned or it may not be partitioned or formatted yet. Right click on the drive to format it and to assign a drive letter. If its already formatted and works on other computers, let me know because it could be a USB error or faulty cable.
Nov 07, 2007 | SimpleTech SimpleDrive...
External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
Oct 06, 2007 | Western Digital My Book Essential Edition...
Electronics - Others Logo
146 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
