Question about Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
Betacam tape eject - Sony Betacam SP Small Videocassette 30 Minutes Digital Betacam SP Tape
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Posted on Nov 26, 2008
Sony Digital Betacam J-30 deck Tape Jam
If you can not fix it then get this new product.
Sep 22, 2009 | Televison & Video
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
Error 20-911
this is the emergency eject / error code 20-911, the manual has this method to solve the issue and have it manually eject
pressing 3 or 4 keys simultaneously; and "left arrow + menu" to get a maintenance menu, then "service", then "manual eject"
Nov 21, 2008 | Fuji M321SP Betacam Tape
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Error 02-603
Yeah, unscrew the 2 top screws. Underneath the lid, there's instructions on how to manually remove the tape. You're also going to have to pull out the tape tray. There's a metal piece holding it down that you can remove by taking out the 2 screws. Then it's a matter of pulling the tray out and turning the tiny gear at the front (not the 2 bigger ones on the side) until it makes the full motion path. Holy ****, that takes a long time. Once you have removed the tape, replace the tray, the holding bar, the 2 screws for that, and the cover.
Dec 17, 2007 | Sony Betacam SP Small Videocassette 30...
Electronics - Others Logo
71 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
