Question about Zebra tlp2844ps Thermal Label Printer
MY PRINTER ZEBRA GK888T SKIPS LABELS WHEN PRINTING. IT CANT RECOGNIZE GAPS BETWEEN LABELS. CALIBRATED MANY TIMES ALREADY
MEDIA CALIBRATION DOESNT DO THE TRICK
Go to printer properties , check in the options and make sure it there should be printing in continuous not with gaps,
there will be one option print and one tab will be there with options to either print in continuous or with gaps, so select continuous from the tab and save the changes it will work
Best regards
Waqar Ahmed shahUAE
Posted on Oct 17, 2015
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
jwr1914
  • 31 Answers
SOURCE: Zebra Z4m calibration doesn't work with different labels
You need to run the internal media sensor calibration setup that is built into the menu. This can take a few minutes but will solve this problem. The machine needs to be setup for the media you are running. This is no fun if you have to change a lot during a day and each media type has diferent qualities. It ususually happens when you are using labels from one manufacturer and then switch to a diferent brand. The backing material has diferent characteristics that the machine needs to be setup to be able to handle.
Posted on May 27, 2009
jwr1914
  • 31 Answers
SOURCE: Zebra 105SL label issues
I am surprised that you are using that sequence of buttons to solve this problem. I am pretty sure that they want you to go into the "Media Sensor Calibration" setup in the config menu. It is a bit more complicated than what you have described. I also believe that the size of the gap on two of your labels might be out of tolerance (they are usually 1/8" gaps between the labels). The black marks are a problem for the transmissive sensors. You may need to move the transmissive media gap sensor (remember it has two parts: upper and lower). I would usually setup mine for a place beyond the black mark so that you are looking at just the white paper.
To start out:
1. Load the backing of a 6" strip of media (no label attached).
2. Remove a ribbon (if you usually use one).
3. Close the printhead.
4. Press SETUP/EXIT and then NEXT/SAVE until "Media and Ribbon Calibrate" appears.
5. Press "+" to start the calibration procedure. You should see the "Load Backing" in the LCD Display. You already have the backing loaded so continue to the next step.
6. Press "+" to answer the message and the next screen should say, "Remove Ribbon". You have also removed the ribbon.
7. Press the "+" to continue. You should see the screen say, "Calibrating Please Wait". After the sensors are setup by the machine a new screen should appear, "Reload All".
8. Open the printhead, and move the labels until they are loaded correctly to print. Smooth out the ribbon and load it correctly.
9. Withe media and ribbon now loaded, press "+" to continue and the machine should say, "Media and Ribbon Calibrate".
10. Press the Setup/Exit button once. It should say, "Save Changes Permanent". Press Next/Save to finish the process.
11. Do a normal calibration of your stock and print a label.
You are done. The machine will run for the labels you have setup the sensors for. Unfortunately, you must do this for each of the media types. To automate this, you could run a Configuration listing, capture the settings you just created for each type of label. Take these to a programmer to have them send the setup to the machine before the job. This is beyond the scope of this type support to really help you.
Posted on May 29, 2009
  • 62 Answers
SOURCE: Zebra TLP 2824 Labels printing upside down.....How do we correct?
Change orientation in the printer driver.
Open printer & Faxes folder, Double click on printer driver icon,
Zdesigner driver, click on properties, click printing preferences, tick the box "rotate 180%" Click apply & ok.
If driver is Zebra TLP2824, same as above, but hit the + on "Paper output" and turn "rorate 180%" on, then click apply.
Posted on Nov 20, 2009
Advancing blank labels inbetween printing
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 03, 2013 | Zebra 105Se Thermal Printer
My zebra printer wont line up the labels and keeps saying paper out
run the sensor profile, check if check the gap, run manual calibration, if ask for reload media, please take 3 or 4 labels from the label rolar, put through the sensors (check if ribbon(if use) is install on the correct spots and don't stop the sensors to read the gaps) and run the manual calibration.
Sep 15, 2010 | Zebra Z4M Printer
Settings seem correct, but labels will print on 2 labels, or skip labels. Zebra s4m
The printer is not calibrated to the media length. You need to perfrom a calibration with the labels loaded. This is in the users manual on how to do it. The printer should be set to automatically do this when powered up.
Oct 20, 2009 | Zebra S4M Thermal Label Printer
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Zebra 110XiIIIplus printer
Turn the Printer off and turn it back on. See if it skips a couple of labels. If it does not the printer needs to be calibrated.
Press the Setup/Exit Key and the press the Next Key until you see Media Power UP: IT should say Calibration if it don't then use the arrow keys to get to Calibrate press the Next key again and you will see Head Close select Calibration using the same method mentioned above. After that Press the Setup/Exit Key and Save Changes Permanent. Turn the printer off and on again and the first 2 labels should skip while the printer aligns the media.
Test Print and see if that fixes the problem. Good Luck
Sep 29, 2008 | Zebra 110XiIIIplus Direct Thermal/Thermal...
To start out:
May 13, 2008 | Zebra 105SL Thermal Label Printer
Manual calibration of labels not working, printer not feeding labels correctly
printer manufacturers has different standards depending from the varieties of model and brand of printers for example an epson printer model who is older version is not the same speed print with the recent model likewise with the other brand. Therefore calibration of labels is depending to the version of the printer you are using now.
Apr 22, 2008 | Zebra Z4Mplus Label Printer
Reg. zebra S600 lable
I had this happen when I changed from one label to a different size label. It needs to be calibrated. There are several types of calibration to do to the S600. Here is the solution that worked for me.
  1. Check the position of the laser Media Sensor (figure 13). It may need to be moved to match the type of label that will be printed.
For CARD labels, the media sensor needs to be set at the edge of the card so it can “see through” the notch that is cut on the edge where the perforation is.
    1. For STICKY labels, it can “see through” the backing which shows between each sticky label, so the Media Sensor could be set anywhere for it to work, but will probably be set towards the middle.
Set to Factory Defaults. This is so that all of the following steps will work. I do not need to change the steps based on the type of mode that printer is set up in because it will erase all that by setting it to the factory default. (See figure 14 for buttons)
    1. Turn off the printer.
    2. Hold the FEED and PAUSE buttons down as the printer power is turned on.
    3. Press MODE button four times.
    4. When the defaults are saved to the printer, the CALIBRATE, DARKER, and POSITION lights will all flash.
Test to see if the calibration is set correctly for the label. If not, proceed to the following steps.
  1. Do a Manual Calibration.
    1. Hold the PAUSE, FEED, and CANCEL buttons down as the printer power is turned on, keeping the buttons depressed.
    2. This will run through several labels and do some printing.
    3. Release all three buttons after the CALIBRATION light comes on and then goes back off.
Put the printer into Auto-Calibration Mode.
    2. Hold PAUSE, CANCEL, and MODE down as the printer power is turned on.
    3. Release the buttons after printer is powered on.
Dec 14, 2007 | Zebra Stripe S600 Thermal Label Printer
372 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
