Question about Samsung SCX4824FN Mono All-in-One Laser Printer
Samsung M2675FN fuser unit error
Error code U1-2340 fuser unit failure printer requests turning off and back on again. This solves the issue for a little while, but then the same error code comes up again.
The Machine
  • 788 Answers
SOURCE: I have just replaced cartridges and am now getting fuser low heat error.
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Posted on Jun 16, 2008
antiochpc
  • 1314 Answers
SOURCE: Replacement fuser unit for Samsung CLP-510
The part number you need is JC96-03239C-N
You may order it through this website; you'll need to call them for pricing information. They are a reputable company that I use to obtain parts.
Thanks and please give this solution a thumbs up rating, solving your problem.
Posted on Apr 26, 2009
  • 113 Answers
SOURCE: Samsung ML2571N Fuser Open heat error - Fuser Is Good
Hi Kevin,
The main power supply board in short we call it (SMPS) the error you got is quite common that the main power is not getting in to the transformer in the correct voltage. Normally is to replace the SMPS and the fuser as well.
For more Technical test on the SMPS 1st of all we will test the fuse on the SMPS which is located at the bottom right hand corner. using a multi-tester, 2nd will be the capacitor and 3rd which is the last will be the big and small transformer with power on. note the last test is dangeroures unless you are a electrician experts.
hope this help :)
SamsuTech
Posted on Apr 17, 2010
  • 113 Answers
SOURCE: Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
Posted on May 13, 2010
  • 1833 Answers
SOURCE: Samsung CLP-320 Laser printer On switching on
This is a overheating problem. First try this - Put astack/folded paper under the paper tray position (under the tray handle) -- tothe point that the printer weight actually sits on the folded paper instead ofon its actual foothold. If theproblem still exists, then you may need to replace the fuser. Hope this will help you. Good Luck.
Posted on Sep 02, 2011
Samsung printers
This error is a fuser malfunction. You will need to replace the fuser unit in order to get this running again. A fuser unit will run about $90 for a refurbished unit. You should check the manual for more error codes: Samsung SCX 5635FN Manual
Mar 27, 2014 | Samsung SCX-5635FN All-In-One Laser...
Printer fuser failure
replace the fuser. Fusers have a life span based on the number of prints and not the age.
If you dont print alot on the unit, consider contacting the retail store or manufacturer
Feb 12, 2014 | Samsung Office Equipment & Supplies
Samsung clx 3185 error code u1-2112. turn power off and on but still wont fix the unit
firstly restart the printer, if same error is comimg.
then,
fuser error. replace fuser unit
Oct 26, 2013 | Samsung CLP 315 Laser Printer
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
Fuser unit failure #u1-2113
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Samsung SCX-4100 All-In-One Laser Printer
How to reset bizhub 350
Fuser Warm Up Failure.
This means you either have a fuser unit failure or possibly had a voltage surge. Also sometimes if the machine is turned on in a cold environment this code can pop up. Try resetting ONCE only by turning the machine off, then holding down the utility/counter button while turning the power back on. Continue to hold the button down until you see "Trouble Reset" then touch OK. Turn power off then on again. If the code comes back on after a bit then you will need the machine serviced.
Good Luck.
Dec 25, 2011 | Minolta bizhub 350 Black and White Copier
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
Failure to print
Hy i had the same error message the error comes from the fuser unit , the halogen lamp is not heating , on the top of the fuser unit is a Thermostat in series with the halogen lamp wich u have to replace. Its not that easy if you dont have experince but it will solve the heat error. I hope this helped
May 21, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Samsung 1610 Leaser - Fuser Error
Fuser Error is a Fuser Error no matter what the printer is hooked up to.
Most likely the fuser unit is shot and will need to be replaced. Either the heating element or a sensor went bad and will need to be replaced.
Unless you recently tried to run a lot of pages and it over heated.
Then i would shut the printer off, wait 10-15 minutes and then turn it back on again. If you get the fuser error again, then your printer needs to be serviced.
Feb 03, 2008 | Samsung ML 1610 Laser Printer
Samsung SCX4824FN Mono All-in-One Laser Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
