Question about Panasonic Microwave Ovens
Panasonic Pro 11 Microwave Oven
We turned the rotary timer switch which had come loose and snapped the wires.We gt a replacement part with a note saying this may look a little different but will work with your appliance.Our problem is the wire colors on old appliance are 1 x White 1 x Black and 1 x Brown. The new switch as come in the colors of 1 x White 1 x Orange and 1 x Yellow does anyone know which wires we need to re connect to please
  • 9098 Answers
SOURCE: need replacement bulbs for over-range hood
These are 20W 120V bulbs with what's called the intermediate base. The new Panasonic part number is ANE6030540AP and you can get them at Tritronics at or Vance Baldwin at You should also be able to get them at local appliance parts stores, Lowe's (or similar) or even a large grocery store. You can also use Sharp part # RLMPT0003YBE0 from either of the above sites.
Posted on Dec 13, 2006
  • 3587 Answers
SOURCE: Door Switch- SCA2001 FSS 02 GE Advantium 220v
a parts diagram would be useful here..let me go see what's available
Posted on Apr 01, 2008
SOURCE: replacing- TT Motor- rotates sometimes or stops completely
An AC motor has 2 leads and does not have a polarity. Just conntct the two terminls and reassemble the unit. If nothing else is wrong, it will work fine again.
Posted on Jan 11, 2010
  • 17130 Answers
SOURCE: no power to microwave. I
Look for the surge protector being short which is in the front end after the fuse. If so disconnect and check for the shorrt to change. repeat the same for the power supply to show a release of the short.
If the transformer, main capacitor is shorrt removve and check or replace.
Since the short is in the primary end you can get this sorted out easily as a short in the magnetron might not be worth.
So use the continutiy meter to disable one by one these compenents to confirm.
Posted on Sep 14, 2010
  • 2047 Answers
SOURCE: i have a fridge equipped
Usually the fact that the wires have the same color does not mean that they are meant to go together. But in your situation since the other colors match then they are menat to go together. Although according to color coding the black is meant to be neutral while orange also stands for both wires could go together. But in rare cases the wires coding could have been mixed up so best get an expert to examine it and test the cables to determine which is which to avoid unforeseen damage.
Hope this solution has been helpful?
Posted on Mar 19, 2011
How do I turn on the microwave and set the clock
well setting the clock comes first if my memory is right
Jan 14, 2016 | Microwave Ovens
How do you replace the door switch for the door in the microwave oven?
Take the cover off, the switches should be pretty easy to replace. In the several I've done, they just snap out, unplug, and then snap back in.
Oct 25, 2015 | In Microwave Ovens
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
When I turn on it snaps and smells burnt
your plug wire is loose from inside microwafe tighten it.
Mar 01, 2011 | Panasonic NN-S954WF Microwave Oven
Timer changing but microwave is not turning on?
Hello :
It's a bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
WARNING : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 30, 2010 | Magic Chef MCD1311ST Microwave Oven
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Microwave F-7 Code
F7 is q Power to magnetron
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
How do I take it off demo
timer button 4 time on demo mode
time button 4 taps more off demo mode
see page 11 of your manual
please rate me for this
Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
Timer problem
Sounds like your timer board is fried. Replace it.
Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic microwave
The door switch is faulty and needs replacing.
Oct 26, 2007 | Panasonic Pro NE1257 Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
