Question about GE GSH22JFT Side by Side Refrigerator
Power surge refridgerator not cold - GE GSH22JFT Side by Side Refrigerator
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Top refridgerator does not get cold but the bottom freezer works fine
Most of these have a fan that blows the cold air for the freezer into the refrigiator section. If the fan quits running you will experience your problem.
May 08, 2009 | Refrigerators
Marvel beverage refridgerator is not staying cold anymore
Make sure you have 3-5" of space all around, otherwise it keeps sucking its own hot air and reaches 'equilibrium' and won't get any colder. Ever
Jan 15, 2009 | Refrigerators
Fridge does not come on after power failure restoration
If you don't have a surge protector for your appliances, the sudden power surge can affect the electrical's on your fridge which is probably why it doesn't go on. Also, it sometimes pays to turn the power off at the wall then wait 10-20 minutes before turning the power back on.
Nov 17, 2017 | Refrigerators
Refridgerator no longer colling but fans are working
It impossible to tell via the internet without detailed descriptions of what you have tested, checked etc...However it sounds like maybe the compressor relay has failed if you are lucky, they are only around $50. If the compressor failed, then time for a new one probably if its more than 5 years old or if its a 2006 or newer.
Jan 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Not cooling at all
NEEDS A RELAY IN COMPRESSOR,THEY GO OUT WITH A POWER SURGE,JUST MAKE SURE RELAY IN COMPRESSOR IS HOOKED UP CORRECTLY ,REMOVE COVER FROM BACK THERE IS A SMALL BOX ATTACH TO COMPRESSOR REPALCE
Jan 03, 2008 | Kenmore 55609 / 55602 / 55604 / 55606 Side...
GE GSH22JFT Side by Side Refrigerator Logo
19 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
