Question about Utilitech Plumbing
Sump pump model 0313507 lift time warranty
Where do I get it warranted Portland , maine
3 Suggested Answers
  • 7 Answers
SOURCE: Appropriate size inverter for sump pumps
First...you need to find the amperage on the pump...your inverter is rated for 6.25 Amps...(750/120)...you will need an inverter bigger then the pump..I would suggest at least 1.5 times the size of the pump..bear in mind,..the inverter wasnt designed to start motors...so oversizing is needed..
Hope this helps
Posted on May 07, 2009
mkh5094
  • 145 Answers
SOURCE: just purchased a home with water ace sump pump.
That's the idea; if you lift the float the water starts pumping because it works off of that float. That type of pump is usually meant for water that is in a tub or bucket, so that when the water reaches a certain height and causes the float to rise allowing the pump to kick on. I use a pump like that to pump our the drained water from my washing machine in my basement, i let the water go into a big 50 gallon drum and then once the drum is half full i have it set so the float rises and pumps out the water. That being said, if you are putting this in your basement at floor level, you would need to get a 10 gallon bucket meant for sump pumps (you can get one at your local home store) and rent a jackhammer if your basement is concrete and put the bucket in the floor and the sump pump in the bucket, this is called a sump pit. Another option is to get whats often called a "floor ******" pump. Its a pump that sucks the water out when it reaches around a half inch of depth and it can be used in several feet of water (I've used these as well, there is no float involved), and it can be set on level ground there is no sump pit needed. The one thing with my pump you may not want, is that it's constantly running because its constantly monitoring for water so that a lot of water will not build up (especially if water can damage some thing in the surrounding area) . You can check out all the types at your local home store.
Posted on May 28, 2010
What does f05 mean on a hotpoint washing machine
f-05 usually relates to either the pump being blocked or the sump of this particular model being full of coins, color catchers etc.
first keep it simple, ensure outlet hose is not blocked or kinked....but if not follow these steps
  • To sort this isolate from mains
  • take off back inspection panel.
  • tilt machine forward- get sum1 to hold it for u.
  • The sump is the black hose attached to drum.
  • place a basin under this and loosen jublie clamp using star head screw driver/ 8mm socket,
  • pull sump downwards and remove any blockage.
  • note the plastic ball is part of the sump assembley.
  • refitt the sump again and tighten clamp, pull down firmly on sump to ensure fitted correctly
if there was nothing in the sump it is sumthing jamming the pump, hairgrip, nail, etc.
tilt machine forward as above with a basin ensuring isolated from mains power
  • pump is attached to other end of sump hose, right side of machine as you look in the back.
  • using flat screwdriver lift plastic tag up and slide pump assembley to the left releasing it from base of machine
  • clip of plastic cover from top of pump
  • remove wires from pump
  • u should now be able to turn pump around so u can see 3 hex head screws
  • remove screws taking note of the position of pump
  • remove pump and clear blockage
  • reverse steps to reassemble
if this does not sort it poss a new pump needed
May 20, 2012 | Hotpoint Washing Machines
Eroor code on my hotpoint ultime wt746 = F - 05
Jul 11, 2011 | Hotpoint Washing Machines
Fault Code F5 is flashing was on washing cycle and has stopped on this -
from,
hotpoint ace
Jul 06, 2011 | Hotpoint Aquarius WD640 Front Load...
The f-05 is flashing up on the LCD screen and washer won't spin just stops.model is wd860
Apr 25, 2011 | Hotpoint Washing Machines
I have error f05 come up and now a drum full of water - how do I drain this and get the door open to empty and clean the filter? Believe it could be jammed pressure switch or blockage so need to know...
if this does not sort it poss a new pump needed.
Apr 03, 2011 | Washing Machines
It starts good? but can't stop itself. I have to lift it up to stop it manually. lifetime warranty will cover this? where should I go?
Simer pumps website has a nice trouble shooting section and you can contact them to check on the warranty coverage.
http://www.simerpump.com/residentialpage_resource_ts_sump.aspx
Mar 14, 2011 | Simer 3/4 Hp Stainless Steel Sump Pump
Hotpoint wma66. programme finishing too quickly and water not emptying from machine
does f-05 come up on the display?? if so
Feb 20, 2011 | Hotpoint WMA66 Front Load Washer
Grey hotpoint washing machine wt741g i would like to know what f05 means water still in drum only a little bit of water but when it gets to the last 30 minutes it starts flashing f05 and wont turn off
from,
hotpoint ace
Sep 10, 2010 | Washing Machines
I have a 3-year old SP-500 that failed and my basement flooded. (Lots of damage). The float switch appears to have failed. Is this a manufacture warranty item?
Not after three years. Some pumps are warranted that long but floats are pretty easily damaged, jammed, or put into compromising positions so that they fail to activate the pump when they should. Rigid, on the other hand are very strong in their warranties. Some tools have a lifetime warranty. It is worth a check, but even if they replace the pump don't expect compensation for the dammages you suffered from the flooding.
Nov 01, 2009 | Ridgid 85937 SP-500 1/2 HP Submersible...
Installing a Washer in basement
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Oct 08, 2007 | Washing Machines
Plumbing Logo
237 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
