Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Convergence I have a convergence problem with my colors not aligning. Top and bottom are totally out of focus. Phillips 60 inch I have not been able to find the book or schematic showing how to adjust this. Called the cable representatives who implied the picture tubes are gone. I have reason to believe that's not so. The picture on the rest of the screen is ok. I would like to have a quick adjustment guide and or a schematic showing how to compensate for the out of focus picture and or the references to electronically test. How often are the tubes are placed, estimate cost, etc. Can I do it myself without calling a rip off service representative.
  • snshine1 Apr 28, 2008
    I also own a Philips 60" and across the bottom & up in the left hand corner the convergence is off. The screen almost looks like you are watching tv in 3D. I have gone online to Philips online help and printed off directions on how align the multipoints, but nothing has worked.
  • 92 Answers
It sounds like you have a problem with the IC's. 300-400 is an average price for replacement and convergence
Posted on Oct 31, 2007
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
T V is Phillips 60pw938317f the color alignment is not correct. It is blurry and cannot bring into focus. it developed this problem overnight.
If its out of alignment you need to repair the convergence. You can call in a shop or fix it yourself with parts and instructions from sites such as www.TvRepairKits.com
Jan 10, 2011 | Philips Magnavox 9P6034C 60" Rear...
Have Hitachi 50 inch Projector TV, model 51F500A. Built 6/2004. Picture has shadows, primarily in red color, on objects or writing. Top 6 inches distorted as well as bottom 2 inches. Tried Magic Focus...
that is come from your convergence panel theres
2 ic call stk - xxxx
youe have to replace it and then remake alignement for your convergence you should have it in the menu adjustement then magic focus will finalized and you can replace the 45 volt regulator transistor
hope that give you a idea//and should not be to expensive if you get an honest
good luck
Mar 22, 2010 | Televison & Video
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
60" hitachi 60SDX88B screen shows some green distortions in the top and bottom of the screen. Magic focus does not fix this. Help?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 21, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Picture is distorted w/ aline on top and bottom
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 30, 2009 | RCA HD65W140 65" Rear Projection...
Colors are separated on the top from the left to right
Probably the color convergence is off. I had a similar problem. Have you tried the magic focus button yet? That is located at left in the small front control panel. Power on TV, wait 20 min (according to user guide), then press the magic focus. If that doesn't fix the problem, you could try the service mode alignment procedure. But that's a little trickier. I don't have a link handy for that procedure right now, but will look for it if magic focus doesn't re-align your color convergence.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50ux26b/27k with AP63 chassie convergence problem
It looks like the STK chips need to be replace for fix the distorted colors.
You can download the service manual from here: http://www.eserviceinfo.com/downloadsm/11792/Hitachi_60SX12B.html
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergance adjustment
convergance amp ic bad
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
