Question about Makita HM1800 64 lb. Breaker Hammer AC/DC
How and where to put the breaker grease? - Makita HM1800 64 lb. Breaker Hammer AC/DC
Where do I put the oil?
Most breaker hammers have no oil if they have no high speed.
But special grease with high thermal conductivity.
very important .
If there is loose grease buy a consumables kit only complete , only then it makes sense.
Jun 07, 2015 | Hammering
How do you fix water coming out the top of Delta rp 13740 vacuum breaker?
take out screw and pull apart...make sure you line up parts so you can replace back the same way....after all out turn water on slow to blow out any trash...then get heat proof plumbers grease and grease up all parts...if it has a spring...streatch it out some and grease....put all back and should be ok....if this does not work...may need to get repair kit from plumbing supply house..good luck..
Jul 06, 2014 | Delta RP13740 Chrome Bidet - Vacuum...
Bosch gbh5 will keep loosing its hammer
It sounds like the gearbox oil is getting low. The GBH5 uses oil in the gearbox, not a grease - the grease is used for assembly only. The correct type is a PG-150 (fully synthetic gear oil). Unable to find it in small quantities, I now use PAG150 oil for automotive a/c systems, it's available in small bottles. As for quantity, no-one seems to know... I just fill to cover the big bottom gears.
Jan 18, 2014 | Bosch Brute Breaker Hammer 11304
Breaker
What is this on? If it is a breaker, the grease is to coat the feed wires to keep the corrosion and resistance down
Apr 14, 2013 | Electrical Supplies
WHAT TYPE OF OIL DO YOU PUT INTO A MAKITA 1810 BREAKER
this tool does not require daily maintenance, but if the grease needs to be refilled it takes 60g/2oz of hammer grease part number A-90582. This is packaged in 1oz tubes. They also show oil and that part number is 181118-7. If you go to their site "makitausa.com" you can download or look at the section on maintenance and it shows you how to fill the reservoir. Good luck.
Jun 24, 2011 | Makita HM1810X 70 lb. Breaker Hammer with...
How much and what type of lube do i put in the area where the piston and crankshaft are located?
Best practice is to purchase service kit part # 1617000050 . It is available from several outlets including link below. The kit includes items that need to be replaced at time of lubrication.
If you do not want to purchase the kit then use Bosch 1615430015 Hammer Grease 15oz
Mar 08, 2011 | Bosch Brute Breaker Hammer 11304
How do I drain the gear oil from a Bosch Brute Jack Hammer
Brute hammer uses special grease sold as service kit. This kit contains enough grease to lube hammer and replacement bolts that hold springs along the bottom. Check www.toolpartsdirect.com for parts and kit. Remove the lower half (tube) of hammer, also remove three bolts that hold springs and remove assembly from tube. Wash out old grease. Grease will be oil-like only when hammer is very hot, otherwise grease is paste-like. Good luck.
Jun 22, 2010 | Bosch Brute Breaker Hammer 11304
Won't Hammer!!
try repacking with grease as per service kit 897
http://www.islandhirecentre.co.uk/docs/spares/B10201.pdf
thats the drawing for it
if that fails then its a replace all seals/o'rings i'm afraid
a fairly big job btw
Jun 12, 2009 | Hammering
Bosch Breaker Hammer Service Kit Install
The grease in the upper drive area used to be a purple looking grease and the grease in the barrel was a different color and weight. If you ordered the rebuild kit with the O rings and bolts I would use it in the barrel (light film coat on the parts )
May 10, 2009 | Bosch Brute Breaker Hammer 11304
Makita HM1800 64 lb. Breaker Hammer AC/DC Logo
80 people viewed this question
Top Makita Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Makita Hammering Expert? Answer questions, earn points and help others
