Question about HP LaserJet M5035 MFP Printer
59.20 error on a hp m5035
59.20 error. Changed DC controller and main motor.
  • 237 Answers
SOURCE: hp color laserjet printer gives 55.1 error
  1. Follow these steps to ensure proper reinstallment.
    Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.If the same error message occurs, reinstall the driver that came with your printer, or go to hewlett packards' website for the driver there.If you have done all of these steps and no help go to step number 3.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Posted on Nov 25, 2008
seeker5211
  • 1089 Answers
SOURCE: HP 3600 error59.63
Yellow Print cartridge Drive motor or the Driver PCA.
Driver PCA = RM1-2581-000CN
Posted on Feb 10, 2010
  • 213 Answers
SOURCE: HP Laser Jet 3600 it has a 51.23 error I
Try replacing interconnecting cables - flat ones
Posted on Jun 14, 2010
Testimonial: "It was the cable under the pick up assembly"
  • 2385 Answers
SOURCE: hp printer lj m5035 in 69.30 error
According to Hp official site,
A temporary printing error occurred.Turn the device off, and then turn the device on.
If this message persists, contact an HP-authorized service or support provider.
Goodluck
Posted on Dec 06, 2010
  • 304 Answers
SOURCE: HP Color Laserjet M5035 get`s
First, this model is not color laserjet, only black.
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Posted on Aug 30, 2011
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
Jun 27, 2014 | HP LaserJet M5035 MFP Printer
Error code 59.20
59.XY ERROR To continue turn off then
on:A temporary printing error has occurred.
x:=2 = main motor rotation error:
main motor rotation error- have you recently changed toner or fuser/fixer units- if so remove them and power the machine baack on if you recieve a different error but the printer Turns over then the consumable unit is at fault-this fault has appeared on a number of calls with customers using Cartridge World remanufactured toner. the customer thought they were getting cheap photocopies until the motor siezed and the printer as a whole needed to be replaced, they now use HP toners and have had NO errors since
Feb 03, 2014 | HP LaserJet M5035 MFP Printer
I have a clunking noise on a hp 5035 printer
its the drive gears. I've repaired a few of these, you have to take off the power supply, DC controller, main motor, and strip down the drive assembly to replace about 5 gears - total time to repair is about n hour if you know what you're doing. I wouldn't attempt it if you're not a copier tech.
Apr 20, 2012 | HP® LaserJet M5035 MFP Laser...
HP Color Laserjet M5035 get`s error 30.01.34
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
Jul 12, 2011 | HP LaserJet M5035 MFP Printer
Laser error
You may have to replace the laser/scanner assembly or the DC Controller
Sorry
Jan 17, 2011 | HP LaserJet M5035 MFP Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
HP LASERJET 4 PRINTER
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
Nov 06, 2008 | HP LaserJet 4 plus Printer
HP LaserJet M5035 MFP Printer Logo
352 people viewed this question
Seeker5211
Seeker5211
