Question about Lenovo IdeaPad Yoga 11
HOW ICAN GO TO BIOS - Lenovo IdeaPad Yoga 11
Bios password ican not to remove it and if i remove the battay of bios ican,t remove it either
1) Open up case of desktop
2) Locate BIOS Battery
3) Locate Jumper Switch near BIOS Battery
4) Reposition Switch setting from 011 to 110
5)Reset Computer
6)Reposition Switch from 110 to 011
This procedure resets the Basic Input Output System without having to remove the BIOS Battery. It should solve your problem.
Dec 02, 2013 | Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW...
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
Usb ports quit working on my hp netbook 1151nr mini
Recheck bios and verify usb ports are turned on.not sure how?just let me know ican walk you through this.RICHARDM69
Aug 24, 2009 | HP Mini Notebook
I need a bios password and a one time password so Ican get into the bios
Hello, I can unlock ANY  SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto conradodav@hotmail.com WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
I can also unlock one time password with 16 digit error code:
xxxx-xxxx-xxxx-xxxx
May 10, 2009 | Sony VAIO VGN-FZ470E/B Laptop
Display error with nvida Gforce
1st see from the bios whether you can get the graphics card in the agp slot or not.....try to take the display with out graphics card from onboard.......always check from bios....may be the card is not properly inserted into the agp slot
Mar 14, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Asus update unable to decompress file
Hi cranelegs, just click on this link & it will take you to Asus site for you're board. You can download the BIOS-Utilities & bios file.
http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Good Luck!
Mike
Jun 08, 2008 | ASUS P5VD2-MX SE Motherboard
Acer aspire 9300 backdoor or bios password
Clear Password
PIN Pad: Bypassing Password Check, Keep shorting G3 (2 triangle pad) as above PIN pad and
then powering on the system will force the BIOS to clear Supervisor and User passwords. That
means both the power-on and setup passwords are all cleared.
Apr 15, 2008 | Acer Aspire 9300 Notebook
Restart
dear chama119
scan your pc in safemode by updating your antiviruse(plz disable system restor)
Apr 10, 2008 | Intel D101GGC Motherboard
System error loading
try restarting and go to bios,set to default config.
Also,
This issue may occur if your computer BIOS does not correctly manage or support the capacity of the hard disk on which you are installing Windows XP.
See this article:
http://support.microsoft.com/kb/326676
Dec 15, 2007 | ASUS P4VP-MX Motherboard
Data broplem
have you checked all you condesers? sounds like you might have some that are almost ready to pop...
Sep 19, 2007 | Abit SG-80 Motherboard
Lenovo IdeaPad Yoga 11 Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
