Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Need to replace the Button Release on Kenmore Progressive but can't getting handle taken apart.
I have taken out the screws but not sure how to getting handle apart to replace the Button Release for wand.
SOURCE: Replacing On-Off Switch
use a butter knife...it will pop off.
Posted on Jan 31, 2007
johncaman
  • 201 Answers
SOURCE: Kenmore Progressive cannister electric motor will
Apparently there may be a fuse in the canister itself, I have no instructions for getting to it though. There's another post on here you might want to check, perhaps that person can tell you how to get to it
http://www.fixya.com/support/t1581380-kenmore_progressive_canister_vac
Please rate if this helps :)
Posted on Mar 05, 2009
galati2k
  • 281 Answers
SOURCE: Kenmore progressive bagless brush roller won't turn
belts broke need to replace but before you put the new belt on clean the motor shaft ,broken bels usually leave burnt rubber on the motor shaft.,if you don't clean the shaft the new belt won't last long
Posted on Apr 10, 2009
  • 5 Answers
SOURCE: i need to take apart my Kenmore Progressive
What problem are you trying to fix? The is no belt so you don't need to remove the bottom plate. If you are trying to remove the main hose, remove 4 screws on the back and remove the plate. There are 2 more screws under that.
Posted on Sep 07, 2009
beltronic205
  • 1474 Answers
SOURCE: I need to replace the part of the wand that
Try espares .co/uk
Posted on Apr 05, 2010
How do I take the handle apart on my Kenmore Progressive vacuum model 116.21614011? I removed the screws but it won't come apart.
There are catches that snap the handle together. It's hard to separate the handle without breaking the catches. Replacement may be required
Oct 05, 2013 | Kenmore 25512/ 25513 Progressive Canister...
My Kenmore progressive canistor vacuum has a loose electrical conection in the hose handle. How do you take the handle apart?
There are 3 visible screws there in the handle and one not so visible.
start by removing the 3 visible screws.
Take a flat screwdriver and pry off the colored portion of the handle that would contain the switch.
There is one more screw in the handle just in front of the switch, remove that one.
This is where it gets tricky.
under the handle between the handle and the hose, is a little square shaped pry area that is locked. Use the same flat screwdriver to get at that and release it. The rest of the handle should come apart pretty easy now.
Good luck.
Mark
Nov 11, 2010 | Kenmore 25512/ 25513 Progressive Canister...
I know a toy is stuck there but I don't know how to remove the plate to get to it
There is a push tab on the bottom by the wheels. It is opposite of the handle release. You will probably need a flat head screw driver to release it.
Aug 15, 2009 | Kenmore Progressive Bagless Upright with...
I need to replace the power cord.
You need to remove the handle and the front housing then you'll see where the connections meet. Then you should able to get it off and replace it.
Jul 29, 2009 | Kenmore 31912 Progressive Direct Drive...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Broken power head belt
Not sure which one you have, need complete model number. You can go tosears.com, click on the parts link, enter you model number, click on the powerehead link. A parts list will come up along with a picture breakdown of it.
Alot of them the part covering the light is just snapped into place, push in on the side andback to release it. Remove the 2 screws, use a flatblade and stick in the slot on each side from the bottom and pry up to release it.
The other type, you tak out the 2 screws from the bottom, then on the back and each side are release tabs that you pry out to release.
May 08, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Mar 19, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
53 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
