Question about West Bend 55108 Espresso/coffee Maker
Replacement parts powersupply
Replaced new lamp in sharp pg-d3050 projector, but not getting on only led turn green and then red
then ,check the lamp or lamp ballast (integrated with the powersupply)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 08, 2013 | Sharp Projector lamp Projector Lamp
My asus Eee pc1005HAC powersupply plug short circuited and causing my asus laptop i guess not to turn onn ?What is the volt. and name of the fuse/part that may be needed 2 replace Pls?
for now if you can find someone with the same laptop u can use its battery to check if your laptop will power up and if it doesn't then there might be a prob with ya motherboard.
Aug 27, 2012 | ASUS Computers & Internet
When my unit was set at 120volts...I plugged it into a 250volt circuit ... loud pop ...can it be fixed
Hello, Doing something like that,chances are you blew the powersupply , and hopefully nothing else. You can replace just the powersupply 50 dollars or less, if that doesn't fix it will have have to be serviced.
Aug 10, 2012 | Dell HP-P2507FW Power Supply ** FREE...
Mp8745 fan replacement
The Original lamp
USD110
Have a nice day!
Jun 30, 2012 | 3M MP8670 MP8745 MP8755 MP8770 Replacement...
Hello, I have a 55" Fujitsu Plasma Monitor that's
I have a Fujitsu scaleoview c19-1 bought it 10 years ago with a defect from Germany after it was maybe about 2 years old , the defect where only 2 supression coils that where bad soldered in factory so it was going on and off faultering that was the only problem and curiously all used capacitors are still all well have good capacity after all this years only the seperate powersupply on that monitor has have bad capacitors and 5 pcs replaced inside that unit i have beat it open and after replace all was again perfect. IF you have such a monitor with a separate power supply, beware its only a suggestion to help i have the capacitors in that powersupply replaced a 2 years back and i have no problems anymore but in most cases always powersupply capacitors can best replaced after 6 or 7 years even of a corsair power supply what is also very nessecary to do the Chinese black ones the heat dissipation is higher in power supply s and therefore if the size of the radial capacitors is made its to fit on replace then choose it 10 or 20 volts higher parts in place the newer capacitors are smaller take if possible 105 degrees parts or try an other powersupply to look for the screentrouble if thats not help and of control the graphics card and or powersupply of the computer.
Mar 27, 2017 | Fujitsu Siemens Plasmavision P55XHA30 55...
I there a replacement for a gx280 SFF powersupply?
Your best bet is to take the power supply out and take it to a good electronics store that has decent computer hardware. That way, you can compare the connections available and also its mounting style to make sure it will work.
Sep 11, 2009 | Dell OptiPlex GX280 PC Desktop
Fault alrm
contact xbox customer support for possible replacement, just in case of u left the powersupply to cool down for few hours and didn work.
red light either means, powersupply overheating or powersupply faulty
Jun 20, 2009 | Microsoft Xbox 360 Elite Console
TV wont turn on blinking power light
The powersupply is going bad. If it's within a year old it's probably under warranty, if not look on ebay for "aquos lc32g4u power supply" or "aquos lc32g4u parts" and then replace the powersupply.
Dec 14, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Trutech powersupply, I need an IC
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Aug 05, 2008 | TruTech PLV1615T 15 in. LCD Television
Power supply problem?
Hi ktricks
The problem will definitely be with your powersupply , but before investing in a new one - open up the unit by taking off the top cover and replace the fuse that is on the powersupply - this is 90% of the time the only problem.
If this doesn't work , please supply me with the part number on the part and also with your country you are in and I'll send you the pricing and dealer's contact details.
May 17, 2008 | Sanyo PLC XP41 Multimedia Projector
West Bend 55108 Espresso/coffee Maker Logo
26 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Paul Bade
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
