Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
D1 dedicated micros says kbd not attached? - Dedicated Micros Digital Sprite 2 RS Video Recorder
How to get lumix g1k to work with an adapter and legacy lens. in viewfinder it states "make sure lens is attached correctly
On page 141 the manual says
[PLEASE CHECK THAT THE LENS IS ATTACHED CORRECTLY]
• Check that the lens is attached correctly and then turn the camera off and on. > If the message persists, contact the dealer or your nearest Service Center.
on page 14 the manual says :
This unit can use the dedicated lenses compatible with the Micro Four Thirds System lens mount specification (Micro Four Thirds mount) such as the lens included in DMC-G1K. Select a lens that matches the scene being recorded and your use of the pictures.
If you use a lens other than a dedicated interchangeable lens, auto focus cannot be activated and accurate metering is not possible. Also, some functions will not work.
You should put the camera in mode manual, to avoid the error you get.
to see what lens you can use see what the manual says:
Refer to catalogs/Web pages for most current information regarding compatible lenses. http://panasonic.co.jp/pavc/global/cs (This Site is English only.)
Oct 29, 2013 | Panasonic Lumix Cameras
What do the red diodes D1 - D4 mean?
I do not see anything in the manual about LEDs for D1-D4
Super Micro Computer Inc Products Motherboards Xeon Boards X5DP8 G2 .
However if the motherboard is not posting it could be the RAM. One continuous long beep means that there is no memory detected (D1-D4 may refer to the dimm slots 1-4). You can try booting off of a single stick of RAM, and try different dimm slots to get the motherboard to post.
Jul 15, 2012 | SuperMicro SUPER DP8-G2 (P4DP8-G2)...
I was given a Dedicated Micros sprite 2 without a power lead do i need one or can i connect to the computer as a power supply
would need more info as the system needs it's own psu.... are you meaning the power plug 3 pin type that fits into the psu or the 8 pin that fits to the system (would not try that with the 8pin)
3 pin is just standard kettle lead.
Jul 30, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Feb 07, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Hi I have Bought a dedicated micro sprite 2 dvr with no hard drives. I have download the software from dm site and installed them. the dvr boots from it. but i need to restore it to factory settings. I...
tony i have the same issue and it need to go to a repair shop or seller to reset , and it can be expensive if its to go back to dedicated micros. Find your nearest repair shop cheaper in the long term
Aug 24, 2009 | Dedicated Micros Power Supply
Trying to copy footage from a dedicated micros
The model number of the dedicated micros dvr would be helpful. But for most older dvrs need cd-r. Not cd+r. If after using the proper cd you still can't burn the cd then you may need to replace the cd drive. It's a pretty simple procedure to change out the cd drive. Hope this helps.
Jun 08, 2009 | Ritek (R80JS52RDCB100) 100 Pack 52x CD-R...
Dedicated Micros ECO 4 password needs to be reset.
Hi, we can assist in identifying the password - contact jason@theparadoxgroup.co.uk
Jan 29, 2009 | Dedicated Micros 4way 40GB DVMR wPPP w/...
For got my pass word
As a reminder, the password is set using the camera select buttons. Depending on your model, there are only those limited selections to help you try and recall the password. Unfortunately, if you can not, D1 Sprite 2 systems must be returned to the manufacture to have the default password reset.
Jul 18, 2008 | Home Security
Televison & Video Logo
157 people viewed this question
Top Dedicated Micros Televison & Video Experts
Electro Med Services...
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
