Canon ap 160 typewriter
How to turn off print display
Canon ap350 typewriter
I believe there is a lever (maybe green on the lower part of the print head for copy adj.
DickyO
Jan 28, 2014 | Office Equipment & Supplies
6 beeps when I turn it on
Is there a message on the display like KEYBOARD if so
it needs a keyboard, if not be sure the print wheel is fully installed.
DickyO
Aug 28, 2012 | IBM Wheelwriter 30 Typewriter
Using a Canon AP and must've hit something...now all of my typing is delayed until I hit return. How do I get this off?
I,m not real familiar with canon but they usually have a slide switch on mthe left side of the keyboard try it in different positions.
DickyO
Feb 24, 2011 | Office Equipment & Supplies
Canon 800 series typewriter nothing printing except in memory
There is switxch somewhere with three positions, one for memory print, one for after a line then print and one for type directly, from memory it is indicated on display edged via arrow, but it has been long time since I've work on these, not many typists these days....
Nov 05, 2009 | Office Equipment & Supplies
IBM Wheelwriter 3500.
Does the display show aP/W nomber other than 001?
If it does hold the code key,press and release the "L" key type 001 release the "L" key this sets the keyboard to U.S., if this works the cure is to replace the keyboard.
DickyO
Dec 19, 2008 | IBM Wheelwriter 30 Typewriter
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Canon Typestar 6 operation
I believe there is a mode key. Press it until np appears in the display.
DickyO
Aug 28, 2008 | Office Equipment & Supplies
How can I reset the margins of my Canon AP 610
Thanks, but I already solved the problem!!
Mar 04, 2008 | Office Equipment & Supplies
Hello, I need directions on how to reset the margin on a Canon AP 610 Typewriter, otherwise I'll go nuts!! I've already tried each single combination.. please help me!! Thanks! Kathi
Position the carrier to where you want the margin. Use the margin release to get past the current margins. set using the margin set buttton. Lawrence
56 people viewed this question
k24674
