Question about Jamo Cornet 175 Speaker
Need front speaker covers for jamo cornet 175 speakers
  • 19 Answers
SOURCE: sound faliure
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amplifier could be fried or u have a loose connection inside the box
Posted on Apr 03, 2009
AJIN G
  • 6694 Answers
SOURCE: would this speaker work in the jamo gf-25 ?? and
hi,
it will not be a perfect mach. u have to purchase a speaker with long term power handling capacity of 150W and 4 ohms impedance.
ok
Posted on Jan 06, 2011
  • 1156 Answers
SOURCE: Does a repair manual or
Hi, it is available ,but you will have to pay for it before you can download the service manual..
http://nitrodownloads.net/search/jamo%2Ba3sub.5%2Bspeaker%2Bservice%2Bmanual
Take care.
Posted on Sep 18, 2011
SOURCE: I bought a used like
Hi Sir,
I am Ashish from India. Sir do you still have Jamo Center 200 Speaker? Actually I also have same speaker but it is used/second hand and have had some repairing work done on it. It's crossover also had some manipulating. Now this speaker doesn't perform very well so I need complete details of parts for Crossover/Network circuit of this awesome speaker. So can you send me image/photos of your Center 200 Crossover/Network circuit so I can identify the values of Capacitors, Registers and other parts. And also send me image of Woofers & Tweeters back panel.
Thanks
Ashish
Posted on Aug 23, 2012
  • 28 Answers
SOURCE: i have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Posted on Sep 13, 2012
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
Need to replace Jamo DVR-50
The impedance may be marked on the actual speakers inside the enclosures.
Jul 04, 2017 | Jamo DVR-50 System
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
Sep 13, 2012 | Jamo SUB 200 Subwoofer
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
My Technics SU A700 mk2, doesn't have any signal in right channel. During (i am first owner)time I noticed that I had that right channel performance reduced arround 15% compared with the left one. ...
Have you tried cross-plugging the speaker cables (i.e. swapping left and right channels) to be absolutely sure it is the amp ? I have a speaker that needs a fair amount of volume to wake it up, but after that performs well.
Jun 15, 2017 | Cameras
With my jamo speakers what should my settings be with my 1. Center delay 2 Surround delay 3. Dynamic range Also what should the db be set at for each of the front, rear and center speakers. ...
Those settings would be through your electronics that drives the speakers, usually using test tones and either special microphones or your own ears. Look at the manuals.
Aug 21, 2011 | Jamo A 310PDD.1 System
One Tweeter died, burned... could I replace it? Where I find it? How much it cost? Thanks
I could be replaced even if not the original what make and modle is it Pro Line Music 215-736-8055
Dec 11, 2009 | Jamo Cornet 145 Speaker
Speakers for pioneer vsx 1018
I think you're making this way more complex than it is.
This unit should have no trouble with any reputable speaker. Don't read too much into short term impedance readings as long as you run only one speaker per channel. Every speaker has a dip somewhere in its frequency range and the Pioneer will probably protect itself and the speaker should impedance or current get too out of whack. This is a high end unit and has plenty of clean power to feed any speakers out there.
I'd buy it if I didn't already have a 6-year old predecessor (VSX-T36TX) that I paid twice as much for and has only 5 amplified channels, less features and lower power output. ;-(
Good luck and happy listening!
Mar 28, 2009 | Pioneer VSX-1015TXK Receiver
Jamo Cornet 90 IV Speakers - Woofers need replacement
I had the sub woofer problem what i did was i found the fuse in back of the unit i took it out with a srew driver. I looked in the light to see if the tube had a smoke shot in it and it did then i got some aluminum foil just a tiny piece and put it around the tube and low and behold my unit pop back on what a relief. The foil is for testing only you need a fuses to not cause a fire!
Posted by charles on Jan 12, 2009
Jan 12, 2009 | Audio Players & Recorders
Jamo Cornet 90IV
not sure what size you need but dayton audio subs are pretty killer check them our parts express usa, i a have a set of realistic mach ones with one of my drivers blown i did some searching and found parts express, due to rave reviews and the specs on what i look for in subs dayton is the way to go,happy hunting-z
Jan 10, 2009 | Jamo A4SUB Car Speaker
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
 Grubhead
Grubhead
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
