Question about Panasonic NV-GS15 Mini DV Digital Camcorder
On switching on, it says push to reset
Whilw switching on, the camera says "push the reset button", but on doing so, the error doesn't go away
3 Suggested Answers
thaurfen
  • 623 Answers
SOURCE: error message "push the reset switch"
Set the cam. to whatever you're going to do, record or play. Check the DV tape record/play tab is in the correct position. Turn cam on. open clamshell; insert tape correctly and always push PUSH to close and start the loading sequence.
A couple of things to avoid. When playing a tape, never press tape rewind without pressing stop tape first, the cam. will likely jam. Reported here early last year.
Make sure the cam. strap is pulled clear of the clamshell when opening it. It needs to open fully to start the transport opening sequence. Don't repeatedly load and unload the tape without running it
Posted on Aug 20, 2008
  • 4 Answers
SOURCE: NEED HELP
G'day,
I also have the same problem and after almost buying a replacement I thought I would try one time to get it to go.
What I did was start the cam without a tape in it, let it bring up the little red icon indicating no tape inserted, (it hadn't started flashing "PLEASE RE-OPERATE AFTER PUSHING RESET BUTTON" at this stage) then I inserted my tape. Hey presto, it works although for how long I don't know. I'll immediately start burn my tapes to disc while the going is good.
Hope this helps someone
Posted on Feb 21, 2009
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
How do you reset the shut off switch on a 1990 Ford F250
the fuel shut off switch? simply push in the red button on top of the switch. if it doesn't click when you push the button the the switch wasn't tripped.
Aug 01, 2011 | 1990 Ford F250
When reviewing pictures, by pushing the arrow, a screen comes up over the picture, detailing Camera, date, time, etc. How do I make it go away and STAY away? If I hit the Enter button, it will go away,...
You cannot make it STAY AWAY. THat buttn, the multi-selector switch, is useful. If while viewing your shots it is pressed to the right, then the shot info comes up. Push it once back to the left and that info goes away. If pushed left once again, you get a histogram of the phoro. Push it once to the right and that histogram will go away. without the histogram or information on the screen, you are in normal viewing mode and pressing that multi0selector switch up or down will cycle through your photos.
Oct 31, 2010 | Nikon D50 Digital Camera
Push the reset switch
The means that the powerup self test is not completing successfully. If there is no error indication in the viewfinder, this unit will need to see a Panasonic servicer for repair.
Dan
Oct 19, 2009 | Panasonic NV-MD10000 Camcorder
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
Aug 10, 2008 | Panasonic PV-GS300 Mini DV Digital...
ERROR C-3101
this is a fusing pressure roller code.....
The way to clear the code is by opening/closing the front door.
Apr 04, 2008 | Konica Minolta bizhub C351 All-In-One...
Wont stay on
I just contaced Sony support for the exact same problem. If you're able to power the camera on in VIEW mode, open the rubber tab to expose the USB and DC In connections, directly above that there is a small RESET button. Get a paperclip and push and hold the button until the camera resets itself. This fixed my problems, hope it will fix yours!
Nov 06, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Push the reset button,PANASONIC NV-GS11
My NV-GS15 asks me to push the reset button every time I turn it on
Sep 15, 2007 | Panasonic NV-DS50EN Mini DV Digital...
Focus
This camera has TTl auto focus so it can't be switched to manual so that idea is quickly stomped on. A silly question, are you half pushing the shoot button down first to activate the auto focus. If you don't and just hit the shoot button you'll definitely get out of focus shots. Have you sat down and read the manual on how to correctly focus. A number of things can crop up which can fool the autofocus into a wrong setting. Have you dropped the camera or has someone else done so? The lens assembly could be damaged. Try pointing the camera at something about three feet away whilst half pushing the shoot button then still holding the button half way point the camera at something a long way off. Can you hear the mechanism trying to focus and does the picture in the LCD change. If it's all quiet and the picture doesn't change then it could be a damaged focus motor or a connection to it is broken. Are you sure the camera isn't switched to Macro. A lot of people get caught with that one. You'll never shoot a focussed picture in macro unless it's less than a foot or so away. BMW
May 31, 2006 | Samsung Digimax A400 Digital Camera
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
15 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
