Question about Canon Office Equipment & Supplies
IR 7105 no sign of display
While i was removing the jammed paper from the fusing unit all of sudden went to sleep mode no sign of display except green light is on
SOURCE: paper jam
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Posted on Dec 04, 2008
SOURCE: We have a Canon IR-7105
it is a transfer corona problem ,clean it first.even its not ok change the corona wires.
if its not ok finally change the transfer corona .
Posted on Jan 21, 2009
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
  • 133 Answers
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
Posted on May 23, 2009
FixinFax
  • 3085 Answers
SOURCE: canon ir 2016 is displaying
there is a black switch knocked out of it's holder.
Posted on Feb 14, 2010
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
I have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Apr 24, 2010 | Office Equipment & Supplies
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
Kyocera FS4020DN is showing paper jam in display with directions of how to resolve this issue. There is NO jam-and directions have been followed numerous times-printer has been restarted -numerous...
After removing paper tray, above the paper tray slot, on the bottom of unit, left side, is a green tab. Pull metal flap down, remove paper, and your in business. That is just my experience with my friends unit.
Oct 16, 2009 | Office Equipment & Supplies
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Paper jam
remove the tape pick up assambly, gently increase tension of spring and fix it.
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Canon iR 7105
The Tray A Area Sensor Unit may be faulty. Replace the Sensor
Oct 27, 2008 | Canon imageRUNNER 7200 Copier
13 people viewed this question
old marine
old marine
