SOURCE: how to reassemble the hilti hammer drill, had to
Go to Hilti.com and then tech service open and scroll down to find the type of tool and then the model number and you can download a schematic for this. Let me know if you still need help
SOURCE: hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
SOURCE: Where can I find manuals on hilti hammer drills,
I willgladly email you schematics however TE52's are very old and parts are no longer available for this model
[email protected]
www.wysehire.gi
SOURCE: drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
