Question about John Deere Garden
Case 4230 stuck in 4 wheel drive - John Deere Garden
SOURCE: My 2007 Trailblazer is stuck in 4 wheel drive!! Help.
shift into neutral while the truck is running and switch it. it might take a second and make a thump but that should work.go into 2 high.being in auto seems to lock it up.
Posted on Jul 14, 2009
  • 17 Answers
SOURCE: stuck in 4 wheel drive and wont come out.
hey there i cant tell you what you are missing but i can tell you how to disengage the front wheels . ok you have a vacum line that runs right under the battery and a line that comes up from the front diff. to the same place ( you may have to remove batt and batt tray to get full access to this) un bolt it and temporaly put batt and batt tray back in start it up and decompress this and see if it comes out .... you should here clunking noise if it goes back in ... if thats the case just pull that big vaccum line off .... to test get all four tires off the ground and have some one put it in drive but dont hit the gas it should turn on its own ...if that dont work check the cable that runs down to the differental
Posted on Aug 06, 2009
  • 1168 Answers
SOURCE: 4 wheel drive will not engage front axle.actuator
On the front axle of your Suburban there is a thermally (an internal heater) activated devise that pushes on a lever to engage the axle. There is a technical service bulletin ( #76-43-01A) on this problem but the repair isn't cheap.It involves installing an updated devise with a DC motor from General Motors which also requires a new wire harness.
I have found that installing an aftermarket one (available at your local autoparts store) that just bolts on will work just as well.
It just threads in to a housing and is very easy to replace.
Posted on Nov 02, 2009
housejess
  • 317 Answers
SOURCE: my 1999 jimmy is stuck in 4 wheel drive
try backing up while changing from 4x4
Posted on Nov 08, 2009
  • 538 Answers
SOURCE: 2000 blazer 4 wheel drive problem
It's most likely the "four wheel drive actuator" This is located on the front differential housing. It's cylindrical shaped and has a large hex (about
1-1/4") and two wires coming out of it. Usually they short out and blow the fuse but, I've also seen where they just quit working and sometimes they just get slow to work. The "actuator" has a heating element in it and it warms up, some sort gas, causing it to expand thus engaging the front wheels. In cold weather it may take a minute or so for it to engage, so put in four wheel drive and wait for a bit and see what happens.
Posted on Jan 05, 2010
Transfer Case stuck in 4 wheel drive
To Troubleshoot Transfercase stuck in 4wd issue.Click the link below and follow the details:
http://www.allcarhelp.com/2015/04/transfer-case-stuck-in-4-wheel-drive.html
This will help.
Thanks.
Apr 14, 2015 | 2000 Chevrolet Silverado 1500
Stuck in 4 wheel drive
sticking solenoid on your gearbox check the wiring for rust clean it.
Dec 15, 2013 | Chevrolet S 10 Cars & Trucks
4 wheel drive won't disengage
There can be a linkage adjustment problem. Also you may need to remove transfer case housing to check the spring inside. There is a chain inside. That one should be checked for its tension. If those are ok you may need your transfer case get serviced.
Nov 25, 2011 | 2002 Jeep Grand Cherokee
When put into 4 wheel drive, my 1998 ford 150's indicator lights come on, but the 4 wheel drive will not engage
sounds like the drive motor on the transfer case is stuck in one position. On the the transfer case there is a small motor that looks like a window motor, you could try getting the indicator on, and lightly tapping the motor to see if the armature is stuck.
Oct 23, 2009 | Ford F-150 Cars & Trucks
Cant move transfer case shifter from 2 to 4 wheel drive
go to car wash spray back wheels enough to remove dirt.
Apr 23, 2009 | 1994 Jeep Cherokee
I had same problem you need to change the switch on dash and/or the actuator in the transfer case
Apr 11, 2009 | 2002 Chevrolet TrailBlazer
2001 Dodge Durango
Many times this type of issue is caused by the motor that changes the transfer from 2 to 4 wheel drive, they get stuck, another issue is dirty fluid, have you had the transfwer case serviced?
Sep 07, 2008 | 2001 Dodge Durango
Garden Logo
37 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
