Question about D-Link Computers & Internet
DCS 5020L connects but after awhile receive message loss signal
Ic been looking for a rpm signil in my 2002 Chevy cavalier
Where have you been looking ? RPM signal for what ?
Tachometer
The IPC displays the engine speed as determined by the BCM via a class 2 message. The BCM receives a class 2 message from the PCM indicating the engine speed. The tachometer will default to 0 RPM if:
• The PCM detects a malfunction in the engine speed sensor circuit.
• The IPC detects a loss of class 2 communications with the BCM.
• The BCM detects a loss of class 2 communications with the PCM.
The CKP sensor is used for ignition timing, the fuel injector timing, misfire diagnostics and tachometer display. The CKP sensor is connected to the ECM by a signal circuit and a low reference circuit.
Jul 20, 2017 | Cars & Trucks
Samsung ace problems
Hi! Your problem could be any of the below:
1-Your SIM could have faulted, resulting in signal loss. Try to put another SIM in your phone and see if problem persists.
2-Your phone antena could be damaged, thats why it keeps losing the signals.
3-There could be software issue which is causing the phone to not receive the calls and messages.
For problem, 2 and 3 take your phone to a service center to get it checked.
Hope this helps you!
Feb 03, 2014 | Cell Phones
Second level tv has a signal but the main tv on first floor has no signal.
Hello! It sounds like there are a few things that could actually be going on. If you are getting no picture on the TV(you have a black, blue, or snowy screen), you will want to make sure that the TV is on the correct channel and/or input. You will want to be on channel 3 or 4, and possibly on a Video 1 or 2 or HDMI 1 or 2 input. If that doesn't work, then try unplugging the receiver from the power source for about 10 seconds. If you are still not getting a picture, let me know!
If you have a signal loss message on your screen (Signal has been lost, Partial SIgnal loss, COmplete signal loss, or Acquiring signal), you will first want to unplug the receiver from the power source for 10 seconds. You will get the Acquiring singla message as the receiver reboots after you plug it in, but that should only be about 5 minutes at the most. If you get the message after 5 minutes, you will want to make sure that all of the cables going from the back of the receiver to the wall are tight. If that still doesn't do it, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP622 DVR DTV Receiver /...
No matter what I do I can not get any signal. When I do test it shows no signal very frustrated
Hi prodriver46,
Are you receiving any error messages on the screen? Usually with signal loss it would be error 015 or 002. I would suggest during a hard reset with the receiver by unplugging it from the wall for 10-15 seconds and allowing it to reboot once plugged back in. If the problem persists run a check switch test by hitting menu on the remote followed by 6-1-1. If you receive any error messages after the check switch we will have to send a technician out to correct the issue. Feel free to e-mail me at nick.franta@dishnetwork.com with any further questions or concerns!
Nick Franta
DISH Network
Apr 23, 2011 | DISH Network Vip 211k High Definition...
My VIP722 DVr keeps showing that I have a complete loss of signal. This goes for awhile and can receive no HD channels. By going to DVR I can then go to guide and get SD channels only. But then after...
Hello this is Nick Franta with DISH Network.
What error message are you receiving on your screen? There should be a 3 digit number in the top right of the message. Has there been any bad weather in the area which may have affected the signal?
If you haven't been advised to already, I would suggest doing a hard reset of the receiver by unplugging it from the outlet for 10 seconds. When you plug it back in the receiver will reboot itself for you. If you are still getting errors hit the menu button then 6-system setup, 1-installation, 1-point dish, and then hit check switch and then test. All your satellites should show green. If not we would need to send a tech out to address the issue.
Hope this helps!
Jan 12, 2011 | DISH Network 311 DTV Receiver
322 receiver trying to acquire a sat signal for 5 days 0 out of 5 progress please help
Hi, Mary with Dish network Customer Service. The issue you are experiencing is a complete satellite signal loss message. If you are experiencing severe weather right now it is best to wait till it passes. Then you can reset the receiver box by unplugging it for 10 seconds from the power and then allow it to reboot. Also check all the connections in the room with the receiver box from the wall up to the receiver itself. If it does not get off 0 progress of 5, you will need to call Dish network and will probably need a Service Technician Visit scheduled.
Apr 17, 2010 | DISH Network 322 DTV Receiver
Dvr wont record correctly. skips every so often saying "dish couldn't play due to loss of signal"
This message will populate when you had signal loss during a recording in progress. If you have great signal and still continue to see these msgs then your reciever will need to be replaced.
Nov 30, 2009 | DISH Network Televison & Video
Enter location message
Joe, have you tried the external yet? Did that fix it? This sounds like a Hard Drive problem, but I would try re-loading /reflashing nand flash before I went the hard drive route. Do you have the software?
Nov 15, 2006 | Magellan RoadMate 700 GPS Receiver
Computers & Internet Logo
16 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
