Xerox phaser 6700 service mode
How to get entrance in SM?
antiochpc
  • 1314 Answers
SOURCE: xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Posted on Jun 23, 2009
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
SOURCE: Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Posted on Dec 10, 2009
Geekman
  • 32281 Answers
SOURCE: Xerox Phaser 6100 vs Windows 7
Try using the Vista driver, it may work and may not have all the functions that was available under Vista.
Posted on Jun 10, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
How do I replace the imaging unit on a 6700 Xerox phaser
If you are not a technician, don't try to do it yourself. Take it to a repair shop.
Oct 06, 2014 | Xerox MAGENTA IMAGING UNIT, PHASER 6700
Xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 7760 saying "black ATC sensor failure - code 009-380", i changed developer and xerox phaser 776
When you have a sensor failure, you need to replace the black ATC sensor and recalibrate it. Another reason for sensor failure is you are not getting toner moved down to mix with the developer...the toner tube/auger spring could be clogged up or not functioning.
Also if you changed the developer housing when you changed the developer, you need to change the value to the new sensor # that comes with the housing.
Feb 16, 2014 | Xerox Phaser 7760DN Laser Printer
Wont print from drawer 2
If you dont have the option to print from your computer it is a driver issue.
If the printer wont physically pull paper try replacing the Pickup rollers
Sep 20, 2013 | Xerox Printer Division Xerox Phaser...
Is there a service mode on the xerox phaser 6500 ?
To enter Service Diagnostics on Xerox Phaser 6500:
1.turn the printer off ;
2.press and hold both the Up and Down arrows and turn the printer on ;
3.when Service Mode and ESS Diag appear on the display, release the buttons. You will need a Service Menu Map to navigate through the menus, they are quite complicated.
Jul 03, 2013 | Xerox 6500/N Phaser Laser Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500DN printer error : 09,037.45:67244
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Jun 19, 2008 | Xerox Phaser 7300DN Laser Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
115 people viewed this question
jasbo
jasbo
