Question about Kitchen Ranges
Control board on frigidaire stove not working
Control board not working oven light comes on , stove top works, outlet has power
fridgetech
  • 473 Answers
SOURCE: Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Posted on Oct 15, 2007
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
  • 2920 Answers
SOURCE: The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Posted on Dec 28, 2008
daddy1264
  • 76 Answers
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Posted on Jan 01, 2009
heatman101
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
My frigidaire stove made a loud pop while oven was on and then lost power....stove top elements working stove clock not working tested fuse, and changed it still not working
Thank you for your post, friend!
I understand that your Frigidaire range made a loud pop while in operation and lost power. I noticed you stated that the stove top is working and you have changed out the control board but the oven is not working. It could be a possibility that your terminal block or wiring harness has shorted. I would recommend contacting a professional technician to come out and perform a diagnosis and repair on your range. This will help to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Feb 24, 2015 | Frigidaire Kitchen Ranges
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
WE have a GE Stove top Range. The burners aren't
If you have power to the stove as in the oven light works and the clock works but the burners and oven will not work you only have 120 volts coming to the stove. The stove requires 240 volts for the burners and oven to work. Check the service panel for a blown fuse. There will be 2 fuses in the fuse holder. One of them is blown. If that is not the case then one of the wires has come loose either in the service panel or in the outlet behind the stove. Use a multimeter to check the input voltage at the outlet.
Apr 25, 2010 | General Electric Stove/Oven/Range Chrome...
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire stove
Sep 17, 2008 | Frigidaire FGFB75D Gas Kitchen Range
F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Dec 20, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
11 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
