Question about Dell 5210n Laser Printer
5210 saying "printer in error state" - Dell 5210n Laser Printer
Error code 3527
Yes; I would find the reciept to the printer and return it to the manufacturer for an exchange for a newer and better one!
Jan 23, 2013 | Kodak Esp 5210 All-in-one Inkjet Printer
Error code 3511
If the cartridge is older than a certain date, even if un used, the system is designed to reject cartrage.
Joe Don
May 25, 2012 | Kodak Esp 5210 All-in-one Inkjet Printer
Error message! I just got a Kodak 5210 printer and it keeps saying "printhead carriage jam. open printer access door. clear any obstruction. check installation of printhead and ink cartilages. close...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Computers & Internet
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
Thanks, Joe
Feb 01, 2011 | Office Equipment & Supplies
Kodak esp 5210 code error 3533 paper jam no paper in it
Leave the rear cover off, then spam the OK button if the error message remains on. I did that maybe 10 times in rapid succession, then hear a very distinctive CLICK in the back of the printer. I replaced the cover, the hit OK, the printer cycled through startup, and now it's operating normally.
Jan 17, 2011 | Kodak ESP 5 Printer
I just installed a new Kodak ESP 5210 printer. It will not print out documents, it will copy and scan though.
OK, did you install the Easyshare software first before installing the printer? I've experienced technical problems with my Kodak camera when I do not have the Easyshare software installed.
Also, how did you install the Kodak ESP 5210 printer? Did you use the driver from the Kodak.com website, or the CD that came with it?
Good luck on getting the Kodak ESP 5210 printer to work on your computer system.
Dec 18, 2010 | Office Equipment & Supplies
Dell 5210 that has a 900.43 error will updating firmware solve this problem?
It may or it may not. I had a 900.43 firmware error on a Dell 2330dn that has a print-que on a Mac server. Firmware update did not fix the issue. I had to clear the print-que on the server. I am not sure what your situation is, but if you have a print server, try clearing the que first.
May 16, 2010 | Office Equipment & Supplies
Dell 5210n Laser Printer Logo
16 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
