Question about Dell Office Equipment & Supplies
Dell 5210 saying "printer is in error state" - Dell Office Equipment & Supplies
Error code 3511
If the cartridge is older than a certain date, even if un used, the system is designed to reject cartrage.
Joe Don
May 25, 2012 | Kodak Esp 5210 All-in-one Inkjet Printer
Dell 5210 cartridge error
There are many cases for your problem:
1. You need to clean the print head and insert the cartridge and check, whether it is working at fine.
2. Nozzle is stuck inside. You need to check for it.
3. It can be the problem of cartridge failure. The cartridge which you have may not be genuine. You need to buy new one and check it is working fine or not.
Hope this helps.
Shane
Dec 21, 2011 | Dell 5210n Laser Printer
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Office Equipment & Supplies
I just installed a new Kodak ESP 5210 printer. It will not print out documents, it will copy and scan though.
OK, did you install the Easyshare software first before installing the printer? I've experienced technical problems with my Kodak camera when I do not have the Easyshare software installed.
Also, how did you install the Kodak ESP 5210 printer? Did you use the driver from the Kodak.com website, or the CD that came with it?
Good luck on getting the Kodak ESP 5210 printer to work on your computer system.
Dec 18, 2010 | Office Equipment & Supplies
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Oct 13, 2008 | Dell 5210n Laser Printer
5310n dell printer
Does it detect an old cartridge properly? Please verify this before disassembling. I've seen incompatible cartridges sent before. The service manual is the same for the 5210 http://support.dell.com/support/edocs/systems/prn5210/
Jun 26, 2008 | Dell 5310n Laser Printer
Will not restart 010-397 states restart printer
I had same problem and called Dell- The 010 errors are all related to the fuser (the thing at the top rear of the 3100) All they had me do was open the rear top cover, pull the outer blue clips and "unplug" or remove and reinstall the fuser. That cleared the error.
Tony.
Apr 11, 2008 | Dell 3000cn Color Laser Printer
46 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
