Washer skips soak cycle - Washing Machines
3 Suggested Answers
  • 116 Answers
SOURCE: Washer skips the spin cycle
Does it drain any at all? Do not think its the sensor - this would give a fault - could be the timer or motor control. If its the timer - maybe just a bad contact or bad relay on motor board
Regards
Posted on Sep 22, 2008
bestdarngood
  • 3037 Answers
SOURCE: Machine won't run the spin cycle
It is most likely a defective speed control or a defective timer. Pull out the timer and clean all metal connections first and if it doesn't work then that is the cheapest part to replace first and see if it is causing the problem. Loose connections or bad wiring might be a possibility as well.
Posted on Sep 23, 2008
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
Jun 04, 2014 | GE Spacemaker WSLP1100D Top Load Washer
Ariston L63S dishwasher does not rinse
Check the screen and the inlet to the pump in the bottom of the washer if it does not empty the water from the wash cycle completely it may not go to the rinse cycle.
Sep 06, 2017 | Ariston Technologies Dishwashers
How does the soak cycle work. Does it start at the end of the wash cycle, or does it drain the soap and soak in clear water
typically on the soak cycle it will fill with water..pause and soak then at the designated time it will advance into the regular agaitate/spin cycle
Aug 26, 2011 | Fisher and Paykel GWL11 Top Load Washer
After filling, stops, lights up cold temp and beebs
are you using the pre soak cycle ? if so it wil start up after the soak time cycle is up.otherwise skip this function.
Jul 03, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Skips spin cycle
bad lid switch or timer do switch first
Apr 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer will not spin properly
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
Apr 06, 2009 | Washing Machines
Washer is not washing the clothes properly. Skipping cylcles
If it's new - check if it's under warranty. Let them solve it. Save you money. You've already paid for it once.
Mar 21, 2009 | Whirlpool Washing Machines
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
Jan 07, 2009 | GE WDSR2080D Top Load Washer
Sep 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Skipping throygh cycles
Timer ? Are you referring to the main control board ? How much extra water is being added on the first cycle ?
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
