How to replace belt maytag model#pAV2300WW - Washing Machines
3 Suggested Answers
  • 142 Answers
SOURCE: maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Posted on Mar 10, 2008
  • 1416 Answers
SOURCE: I have a Maytag Washer
Hello.
BELOW ARE STEP BY STEP RECOMMENDATION ON HOW TO SOLVE THE PROBLEM OF YOUR WASHER THAT HAS FAIL TO WORK AS EXPECTED.
However,if you are having problems with either not draining or spinning, with your front load or top load washing machine, then you need to realize that they can be interrelated. Mostly in that if your washer is not draining the water it will not spin at all or at least not properly. There also can be others problems that will stop or slow down the spin, but the water not draining is the most common one.
So, if you are stuck with a washer that is full of dirty stinky water then here are some things to start checking.
First get that shop vac out or a bunch of rags and a bucket. The water needs to go. The shop vac will pull the water out the drain hose. Just remove it from the standpipe and place the nozzle in the hose and pull the water through the pump and into the shop vac. Of course if you cannot pull the water out this way, you already know that the pump is blocked or clogged, then just vac out all the water you can from the inside of the washer.
If all else fails, remove the front cover and take off the hose going from the tub to the pump. Yeah, water will go all over, but that is what the rags and bucket are for.
When the water is gone, you can then pull all the stuff out of the hose and pump, that are causing the problems. Most of these pumps are very easy to take apart and clean out. This will make sure that there isn?t anything inside the pump that can stop it. They are not very strong motors and something like a toothpick may stop it.
Now, where this get tricky is that there are sensors that check the water level and adjust the spin. If your water is not draining, your washer will not spin either.
For many washing machine problems that are drain and spin related, this simple cleaning will solve your problem. But there are other possibilities.
The lid switch is the old problem that keeps raising it?s ugly head on all washers. Bottom line here is that if the washer thinks that the door is open, the things don?t work right. Check out the door switch to make sure it is operating properly.
Make sure the new front load washers are on a good solid level surface. If the machine can move around then the sensors will often sense the movement and not allow the machine to reach full spin speed. Some manufactured bases may not be stable enough to give correct readings to the machine. If your washer is moving around, then fix that problem.
The timer can also be a problem. Many will wear out and then get to a point in the cycle, then not advance any further. Also the computer controlled sequencers can also get glitches and may need to be reset. You can check out the timer by manually advancing it, and the computer reset procedure will be in your manual that you received with your washing machine.
By going through this check list you can check out the problems that most handy persons can handle in the home. To make sure you have a the best chance at a trouble free washing machine, make sure that you do not leave anything et into your washer that will cause it harm or plug it up.
Thanks for using fixya.
Posted on Aug 02, 2011
I have a Maytag that had a squeeling belt. I have replaced the belts but there seems to be a fair amount of slack in the belt that drives the agitator and there is no adjustment for this belt.
Manuals and Literature - Maytag
https://www.maytag.com/manuals/
MaytagSearch Manuals & Use and Care Guides. Enter your appliance model number to access your Use and Care Guide and any related appliance literature. Use the
Aug 17, 2015 | Maytag Washing Machines
How to replace belt in Maytag dryer DE512
Hello
Watch this youtube video it will show you step by step how to replace the belt
http://youtu.be/6ufArteqWXk
Jul 23, 2011 | Dryers
Screeching noise when agitating and spinning. abrupt stop when turned off. I have a performa model # pav2300ww
you will need a tech tool from your local appliance parts distributor called a brake tool and a brake
Jan 23, 2011 | Maytag Performa PAV2200
Where can I buy a replacement belt for my Maytag Neptune MDG5500AWW dryer?
Nearly every appliance store and appliance repair shop sells replacement belts. Your area Sears / kMart retail store will have them, too. Many hardware stores sell them as well.
if you don't mind waiting, you can find them online, too. Here's a list of places that Google found for Maytag Belts. You should use a combination of Maytag dryer model number and the number that appears on the belt to obtain a replacement.
Oct 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Belt replacement instructions for Maytag Ensignia model MDE4658AYW electrical dryer
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
Jul 24, 2009 | Dryers
Maytag toploader model pav2300WW
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
MAYTAG TOP LOAD WASHER
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
