Question about Canon Office Equipment & Supplies
My canon ir1570f displays platen cover is open please close platen cover on yet it is closed
jaylex
  • 417 Answers
SOURCE: error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Posted on Jan 07, 2008
bowdo
  • 78 Answers
SOURCE: Brother Intellifax 2800
Pls open cover = Please open cover. Probaly has a jam - Open the cover remove the drum/toner unit and check for jammed piece of paper under of in the drum unit.
Posted on Jan 25, 2008
  • 2072 Answers
SOURCE: Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Posted on Mar 21, 2008
  • 4 Answers
SOURCE: Canon Pixma MP600 Printer continues
I had the exact same problem with my brand new MP610, and I finally just turned it off and back on. That appears to have worked.
Posted on Sep 07, 2008
  • 114 Answers
SOURCE: platen opeo error
CLEAN THE PLATEN SENSOR IF NOT SOLVED CHANGED THE PLATEN SENSOR.
Posted on Jan 30, 2009
How to fix platen cover need to closed ir-1210 canon copier
Sep 25, 2012 | Office Equipment & Supplies
Bizhub 211 - doc cover open
Something is open. Check and make sure you closed everything securely.
May 30, 2012 | Office Equipment & Supplies
A customer's ImageClass D880 fax/printer's display reads PLATEN IS OPEN / PLEASE CLOSE PLATEN. At the left rear of the platen is a black vane that rotates into an optical interrupter in the...
I was ever have that problem.
the solution is I moving slide the scanner section more hard then usually.
and I think that is the lock of scanner not fit.
May 31, 2011 | Canon ImageClass D880 Copier
Cannon Pixma IP1600 is full and will not print, how do I fix it
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Feb 26, 2010 | Canon PIXMA iP1600 Printer
Printer says inkjet not installed properly but it is and both are full.
Hi there
4.Close The Cover
Feb 23, 2010 | Canon PIXMA iP1600 Printer
I have a Cannon iP1600 printer and when i want it to print, it tells me that the waste ink absorber is full. How can I fix it?
Hi there
4.Close The Cover
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Every i try to print i get an error message 53 stating the ink cartridge is not installed properly or not compatible with the printer
Hi there
4.Close The Cover
Nov 30, 2009 | Canon PIXMA iP1600 Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
4.Close The Cover
Oct 16, 2009 | Canon PIXMA iP1600 Printer
Canon Pixma ip1700 how to clean a full ink observer?
Hi there
4.Close The Cover
Jul 08, 2009 | Canon PIXMA iP1600 Printer
Error message
Hi there
4.Close The Cover
Jun 30, 2008 | Canon PIXMA iP1600 Printer
56 people viewed this question
old marine
old marine
