Question about Honda Garden
I have recently tried to start myHonda Izy and foundnospark at the sparkplug replaced with ewspark plug still nospark so therefore willnot start spark
    Master:
  • 969 Answers
Replace laminator. Device attached to plug wire. check air gap before removal.
Posted on Jul 04, 2015
2 Suggested Answers
cadman000
  • 607 Answers
SOURCE: Honda Izy will not start.
try fresh fuel
Posted on Apr 05, 2009
What would cause no spark when the starter motor is engaged and spark when the the key is the run position.
It's the safety switch under your seat. Did you sit on the tractor when you tried to start it? If you didn't the spark would have been shorted. GOOD LUCK FRIEND.
Sep 17, 2014 | Garden
Why will the engine not start?
check the coil by the flywheel. It should be just far enough from the flywheel that you can fit a bussiness card in there. There should also be a ground wire coming off the could. When the engine is supposed to stop, the ground wire makes up and shorts the sparkplug, which stops the spark (and therefore the engine dies). I've seen these coils go bad, and I've seen that ground wire stick to something, keeping the circuit grounded.
Aug 13, 2014 | Garden
Will not start theren is nospark
Did you replace the spark plug? Check the continuity from the coil to the plug?
Jan 03, 2014 | Yamaha 2006 Grizzly 125
Cannot remove ignition coils to spark plugs
get a haynes repair manual at your auto parts store
Jan 19, 2013 | 2004 Toyota Corolla
My tomos streetmate r was going full throtle and it started to misfire then the engine died . Wont start and nospark coming out of the sparkplug. whats wrong?
inspect wires for conection n corrosion--coil cud be worn-is it real hot--battery can fail at any time-testit--getta clymer book or other for complete bike work
Aug 20, 2012 | 2008 Tomos Streetmate
Hello i have a Honda izy self propelled it is 3
sounds like your petrol filler cap hole is blocked , try and drill a hole in the cap or loosen the cap slightly , and change the spark plug , the izy can go through plugs regularly, you could try a good wire brushing and set the gap
good luck
Jul 10, 2010 | Garden
Engine will not start in sunne days
Check the coil for fire during the day. Use an inline spark plug tester to test for fire to plugs. Connect the tester between the coil tower and one of the sparkplug wires. Have someone to try and start the car while you are watching the tester. Check each wire from coil to each plug. If no fire then replace the coil. Hope this will help you.
May 23, 2010 | 1997 Dodge Neon
1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Aug 28, 2009 | Yamaha RD 350 Motorcycles
try fresh fuel
Apr 04, 2009 | Garden
Garden Logo
82 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
