Question about HP Pavilion a420n PC Desktop
Won't turn on after power outage
Many years old, all other components power up
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
My xbo was working last night and we had a power outage , then this morning when i check if any electronics r working , everything was fine but when i went turn on my xbox it is stuck on standby mode and...
It sounds like it may have had a power surge. Was it plugged into a power strip, or straight into the outlet? If it was in the outlet, or if the power strip is old, it may not have been protected and you could have fried some of the internal components. Also, did you have an ethernet cable plugged into it? My Xbox got fried a few years ago because of a power surge through my router. If the internal components are broken, the only reliable place to send it, in my opinion at least, is Microsoft's own repair site.
May 14, 2011 | Microsoft Xbox 360 Console
Freezers compresser will not kick on it trys reason:power outage tried un plugging all night still not working
Good day,
Good chance the compressor was damaged. First however, you can check the compressor starting components.
These components are clipped to the side of the compressor and are held on with a retainer clip.
First, unplug the machine, remove the retainer clip and pull the components off of the compressor.
The components are made up of the thermal overload protector, start relay and on most models a start run capacitor.
Take them to an appliance parts house. Most are more then willing to test them for you.
Take the complete model number with you.
If any test bad, replace. If they test O.K. then you will need the services of a qualified service tech to test the compressor.
If the parts test O.K. and the machine is under 5 years old, then call your dealer for a warranty service call, since the outage may or may not have been the cause of the problem. If it is a bad compressor, and no sign of storm damage is apparent, the warranty dealer would replace the compressor free of charge.
Jul 15, 2010 | Amana Refrigerators
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
Dec 18, 2008 | iLO 2600 Television
HP Pavilion a420n PC Desktop Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
