Question about Hitachi Travelstar 5k750 Hts547564a9e384 640 Gb Internal Drive Bay Width 2 12 Inch SATA II Hard Drive
Hitachi 5k750-500 sata hard drive bios password unlocked
SOURCE: Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
hi i bought a 500gb samsung harddrive thinking to install it into my dimension 5000 but i was missing a data cable. i went to dell to ask about where i could find one and they told me that my dimension 5000 wouldnt support a 500gb harddrive. the max apparently is 400gb... if you have managed to get it to work however. please report back.
Posted on Jan 23, 2008
Maanita
  • 1142 Answers
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
Posted on May 04, 2008
  • 153 Answers
SOURCE: Sata Hard Drive not detected on Bios
I would tend to agree that if the ports are set to autodetect it would suggest that they are looking for drives, but go through every item in your bios just to make sure that there isn't some obscure spot where the port is turned off.
If your bios is not detecting a drive your o/s is not going to find it either, and Linux will likely have the driver it needs when you go to load it. What's more, if it doesn't, you're rather hosed until it does.
If everything looks right after checking and rechecking and sleeping on it and checking again, but your bios still won't find the drive, take the drive back and get it replaced.
Posted on Apr 30, 2009
joecoolvette
  • 5660 Answers
SOURCE: I am attemping data recover on Hitachi 80 GB 2.5" SATA hard drive, need instruction to open cover, etc.
Generally there is a small screw, (Or two of them), that go through a thin metal tab, affixed to the harddrive. They usually have a strip of thin cloth, that you pull on, to ease the harddrive out, after the screw is removed. Sometimes it's hard to see.
I have to give you this information in a generic form, because laptops differ in the way they keep the harddrive in. I better go ahead, and tell you, that this specific info may not be available, for your particular laptop. However, you may want to come back, and post the laptop manufacturer name, and model number, in case it is. (I've worked on many, and have a lot of information available, but am being straight up front with you, that I do not have info available for every laptop out there. Just trying to help, is all)
Posted on May 22, 2009
myrlex
  • 674 Answers
SOURCE: Hitachi Desk star 500GB SATA drive
HOW MANY PARTITION DID YOU MAKE? HOW MANY GB EACH OF ONE.?
MAYBE YOU DID NOT FORMAT THE OTHERS.JUST REVIEW YOUR PARTITION GOT TO PARTIONING ARE THEN REVIEW IT....... YOU FIND THERE THE PROBLEM,, THAT IS HAPPER TO ME BEFORE...BEST OF MY EXPERIENCE....
Posted on Jun 08, 2009
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
Hitachi HTS541612J9SA00 remove password
If you don't now original password you can't remove it at home. Go to a hdd specialist or buy another hdd and change it,
Dec 25, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Hitachi sata 120 gb hard disk lock & password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also if this is a desktop computer
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jul 29, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Protected with password, i want format it and reuse
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Oct 29, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Forgot sata hdd passwords
Try to use Password Unlocker bundle to recover your password.
Oct 06, 2010 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Forgot password
During the boot up process you will see on the screen press delete to enter set up
hope this helps
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
HITACHI HARD DRIVE LOCKED
Hello Oldnovii
This Toshiba notebook has both a BIOS and hard drive lock on it. The client has already paid $ 25 to the Toshiba depot to have the BIOS lock removed now they want $ 100 to remove the hard drive lock. The hard drive lock cannot be removed by trying to bypass it using a boot cd or disabling the hard drive boot option in the BIOS. Any help will be appreciated since my client has now had the notebook for 2 weeks and cannot use it. Thanks
Apr 07, 2008 | Computers & Internet
Hitachi HDD unlock
CHECK to see if HDDunlock.com supports your drive, I seem to remember that they do NOT support Hitachi drives.
Feb 12, 2008 | Computers & Internet
Hitachi Travelstar 5k750 Hts547564a9e384 640 Gb Internal Drive Bay Width 2 12 Inch SATA II Hard Drive Logo
237 people viewed this question
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
