Question about Bosch Food Mixers
Bosh turbofixx how to open - Bosch Food Mixers
KitchenAid standmixer (professional 5 pro) makes clunking noise when attachment is in hub.Grinderworm (from food grinder) slips rotation regularly as well.Without attachment everything sounds normal.
Open the gearbox up and look inside, the damage will be obvious once you clean the grease away. You aren't going to fix it from the outside so opening it is going to be part of the solution.
Dec 14, 2015 | KitchenAid Food Mixers
Runs wide open then quits
Looking at the parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204551.pdf
find item 9. It is a hall effect sensor which measures the speed of the motor and feeds back that info to the controller - if it is open or shorted the motor will not be controlled and will either not run at all or run wide open.
Mar 24, 2010 | KitchenAid KV25G0X Stand Mixer
How to open the Kenwood Chef A700 and service it?
brendan@rmbs.co.nz, hi there guys, I want to lubricate my Kenwood A700 and would really appreciate your assistance as in what I must open and what type of lubricant would be suitable.
Jan 11, 2010 | Kenwood Food Mixers
Kitchenaid pro stand mixer will not turn on I has been sitting for 3 months without being used. It is a 475 watt bowl lift 6 qt mixer. about 3 years old.
How comfortable are you with electrical parts? With the mixer UNPLUGGED and the switch ON measure resistance between the (flat) plug pins. If it's infinite (no meter movement) which is to be expected, there is an open circuit. The switch could be open or the wire to the switch could be disconnected (improbable) or the motor could be burned out and open (not very probable).
Maybe you could take the switch to a shop and have it tested.
This is not really a solution, just step 1.
Feb 27, 2009 | KitchenAid K45SS Classic Stand Mixer
How to open it to change the electric cable ?
I'm looking myself for a guide to open it fully, but I can at least answer your question partly. Maybe you can get on from there.
When you look at the front side of the mixer(the side opposite to the cable), there's a slim oval lid with rounded ends. Push a small flat sdcrewdriver under that lid until it pops out, revealing a screw. Remove the screw.
The rest of the enclosure seems to be held together by several hidden plastic clips. Use a pocket knife with a thin blade and push it carefully between the halves of the case. Work your way from the screw to the top and bottom side, levering the halves apart step by step. Do not use too much force!
I'm stuck at the back of the case where the rubber ring is. I can't get this part open., but it's a start
Feb 14, 2009 | Braun M880 Multimix Hand White Mixer
Can opener
Hello .
if you want assemble can opener to your A701A
the model is : A778
please visit our web site Kenwood Chef Restore in the section download, you find the compatibility of the attachment to download.
also Download in the same section the instruction book for A701A models and there explain how you fit the can opener and another's attachments
regards
Dec 03, 2008 | Kenwood KM800 Major Classic Stand Mixer
Tray doesn't open!
Sometimes the electronic device thats programed to open the door malfunctions from wear and tear or its just defected from the manufacture, if you have warranty send it to Gemsound so they can replace the defected peace.
JLofton(2Housepeople)
Dec 01, 2007 | Gem Sound CDM-150 Mixer
Food Mixers Logo
Top Bosch Food Mixers Experts
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
