Question about Hotpoint WMA58 Front Load Washer
Keeps fillng with water
Wont stop filling up
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Toilet water tank keeps fillng above the water line. No leak anywhere.
Sounds like the float is not attached...it should be attached to the flapper ....it may need adjusting
Oct 16, 2012 | Fluidmaster Toilet Tank Complete Repair...
Fills with water but wont stop filling and wont change to different cycle just keeps filling
check water pressure, it need to be about 20psi. also remove fill hoses and check the screens for dirt. clean it if necesary. also check water valve at fill hose connection. it has screens also. clean if needed. if all is ok then replace water valve.
Feb 07, 2011 | Washing Machines
Fill stops intermittent repeatedly.
Several of the washing machine controls are also responsible for the washing machine not draining, continuing to fill or fillng too slowly. If the washer doesn't want to drain or stop filling, the issue could be the pressure switch. When water enters the machine, water also fils a tube in the pressure reaches a certain point, it triggers a switch that will stop the machine from filling. Locate this pressure switch on your machine and look for damage. If you have a multimeter, use it to find any electrical issues. If there is no reading, the pressure switch needs to be replaced.
Jan 28, 2011 | General Electric WHDRE526EWW Top Load...
My washer keeps filling with water. It wont stop filling on small med. Or larg. It just keeps filling.
If the machine keeps filling even when it is off the water valve is defective. If it stops when you shut it off then, You may have a damaged or disconnected pressure hose. This is a clear rubber hose that runs from the side of the wash tub up to the load size switch. Inspect the hose as best you can.
If the hose is in good condition and is connected at both ends then you have a defective pressure switch.
Jun 11, 2010 | Washing Machines
Washing machine starts filling then wont go any
there are a lot of questions of a simular nature check the diaphram switch this controls how much water is taken in and wont progress until the switch says so what you dont say is if the machine keeps filling or stops filling and wont progress
Jan 16, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
WATER NOT FILLNG IN GE PROFILE DIHWASHER
It ended up being a simple fix. Soap had dried on the floater (water sensor device) and it could not move, therefore no water was going in. I poured hot water and vinegar into the washer and ran a complete cycle and it is working fine now
Jun 10, 2009 | GE 24 in. Profile PDW7880G Built-in...
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Bosch dishwasher
i know this sounds daft but --
turn off water. disconnect fill hose from water supply. wait 5 seconds and reconnect fill hose then try it out
Oct 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Hotpoint WMA58 Front Load Washer Logo
12 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
