Question about Compaq Hewlett Packard Presario SR5152NX PC Desktop
Doesn't boot, monitor is blank, beeps post code
Short beep, long beep, pause, repeating
Ravege
  • 327 Answers
SOURCE: Compaq computer doesn't boot, no
welcome to fixya
does the computer turn on?
do any or the lights come on or is it just dead?
if compute does not turn on then you might want to make sure ever thing is plug in ...
if ever thing is pluged in and and still does not turn on this might be the power supply has gone bad ...
if computer turn on and nothing happens this could be a bad hard drive or the OS has messed up first try to but in your reboot disk this still nothing happens then the hard drive could be broken
hope this helps you out have a good day
Posted on Aug 04, 2008
siawolf
  • 749 Answers
SOURCE: wont boot up
we need to open the case and inspect the cables and cards and memory to make sure nothing has gotten dislodged. heres how to get into the case.
Before Opening the PC
Remove any diskette or optical disc (CD or DVD)
from the PC.
2 Disconnect the modem/telephone cable, if present.
CAUTION: To reduce the risk of personal
injury from electrical shock or hot
surfaces, disconnect the power cord from
the wall outlet, and allow the internal
system components to cool before
touching.
Disconnect the power cord from the electrical outlet
and then from the PC.
4 Disconnect all other attached cables (such as the
keyboard, mouse, and monitor) and all external
devices.
Removing the Side Panel
Remove the side panel by loosening the screw on
that secures the panel to the PC chassis.
2 Slide the panel back about 1 inch (2.5 cm), and
then lift it off the unit.
WARNING: Beware of sharp edge
Once the side panel is off you will see the computers internal parts. Follow all the cables from the power suppy (top rear of tower) to th devices on the other end and make sure all are COMPLETELY in the sockets. Now do the same with the rest of the ribbon cables.
Now check all add-in CARDS installed into slots on the main boardand make sure they are ALL the way into there slots, sometimes these gets jarred or bound by the case and will work thier way loose.
Last check the RAM, the small rectangular shaped sticks with chips on them installed into similar slots on the main board, these can be up just a tiny bit in thier slots and the computer will freeze.
While you have the case open take note of any burnt smells or apparent swollen parts (capacitors), fans not working (inside & out).
It could also be your power supply going out, ive seen em light up the light on the mainboard , but not have any power to the harddrive and lock a system up.
Go through these things , it might be these , it might be something else, but its good to know your computer is clean and all mechanics in it are working visually from time to time. i can of compressed dust remover spray goes a long way to clean out those dirty fans and heat syncs underneith them.
try this and post again ....
Posted on Oct 15, 2008
stif_NEC
  • 441 Answers
SOURCE: when my computer boot,itbeeps 3long beeps over and over.
take the memory out and the video card then clean the teeth of the cards using the eraser of the pensil then put it back. then try to boot again
Posted on May 20, 2009
Geodavis
  • 45 Answers
SOURCE: compaq evo d51s beeps on boot
Try replacing the RAM (Random Access Memory) Stick
Thanks
Posted on Oct 25, 2009
SOURCE: upgraded RAM in D51C, from 256 to 2GB, got 1 short beep, 2 long
It is the same... 1 short beep and 2 long..
Posted on Nov 02, 2009
Optiplex 760 beeps and won't come on
Count the beeps, it is a code that can tell you why the computer won't come on. There can be short and long beeps, a pause, then it repeats, it will repeat 3 times. You can check what the beep code is
Computer POST and beep codes .
Nov 25, 2016 | Computers & Internet
How to boot dell inspiron one 2020 when it only beeps
the number of beeps will tell you what the problem is the beeps are an error code here are the code list for your computer
Beep Code Description No Beeps No Power, Loose Card, or Short. 1 Short Beep Normal POST, computer is ok. 2 Short Beep POST error, review screen for error code. Continuous Beep No Power, Loose Card, or Short. Repeating Short Beep No Power, Loose Card, or Short. One Long and one Short Beep Motherboard issue. One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. One Long and Three Short Beeps. Video (EGA) Display Circuitry. Three Long Beeps Keyboard or Keyboard card error. One Beep, Blank or Incorrect Display Video Display Circuitry.
May 25, 2014 | Dell Inspiron One 2020 All-in-One Desktop
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
Hard drive beeping noises
Never heard of a Harddrive beeping before, but I'll take your word for it.
The beeps you hear are BIOS Beep Codes.
The computer's way if telling you something is wrong, and an area to look into for it.
The beeps are a pattern, or Code.
For example; 1 Long beep, a pause; then 3 Short beeps.
One Short beep, pause, Short Beep, pause; and repeating over, and over.
So....................in your own words Eric, tell the jury where you were on the night in question?
Do you have any alibi's?
WHAT? !O_O!
I mean................what is the beep code you hear?
Plus what is the Product Number of the HP desktop computer?
This can be found on the back of the computer, in the white Service Tag.
P/N = Product Number
Post back in a Comment.
Regards,
Ol' whats-his-name
I mean joecoolvette
Mar 08, 2013 | HP Computers & Internet
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
Winwos doesn load freezes
how many beeps... what kind of pc? below is the standard beeps codes with the the issue.
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Jun 18, 2010 | Western Digital My Book Home Edition 500...
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
thnk you.
Nov 29, 2008 | Computers & Internet
Wont Post get 9 beeps!
This problem is due to the mix of registered and unregistered DIMMs. 64Mb and 128 Mb DIMM's are unregistered memory technology 256MB is registered memory technology. A mix of registered and unregistered memory prevents the server from completing startup, and results in an error beep sequence and a blank screen
Oct 08, 2007 | IBM Netfinity 3500 M20 8657 Server
Compaq Hewlett Packard Presario SR5152NX  PC Desktop Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
