Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
Mf toolbox requires at least 800x600 256 color display?
If you're using Surface Pro 3 that switches between landscape or portrait modes, ensure your display setting is in landscape mode in order for mf toolbox to run.
Posted on May 30, 2015
How do get mf toolbox to see both my printers again?
be sure all drivers are installed, both machines are the same model?
May 01, 2014 | Canon Office Equipment & Supplies
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
Jun 24, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
Canon mf 5770 problem : opening the mf toolbox 4.9, the twain driver will not be shown, programm quits. running the setup utility of mf tool box again, it works, until system reboot, then the same...
I have the same problem. You can't use Canon Toolbox 4.9x. It does not work. You will have to download and intall the x64 driver only from the Canon website for the MF5770.
Unpack the x64 driver and install it.
Go to the Start-menu and click on Units and Printers. Right-click with your mouse when hovering over the printer, then choose scan, fax or print.
We can only hope that Canon will solve the problem in the future, most likely not since MF5770 is an older Multifunction-machine.
Jan 05, 2010 | Canon imageCLASS MF5770 All-In-One Laser...
Need a driver for my Canon series MF3200
The driver with my canon MF 3200 series does not compatible with my 64 bit vista laptop , also Canon MF Toolbox 4.9 does not respond because the message appear told me that the supported scanner does not installed
Apr 01, 2009 | Canon Office Equipment & Supplies
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Printer won't work with new computer
I don't understand why my approach worked, but it did. Having tried all of the reasonable and obvious things, I downloaded an update of the Canon toolbox, which has to do with scanner operations rather than printing. Still, once I did this, I was able to use the MF4100 laser printer with my new computer.
Faith
Sep 11, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
315 people viewed this question
old marine
old marine
