Question about Fellowes Saturn 2 A3 Laminator Laminators
VERY NOISY AND SLOW TO FEED - Fellowes Saturn 2 A3 Laminator Laminators
Wire feed moter problem ?
erratic wire feed speed can be from worn inner liner in the lead
the inner lining is like a close woven spring and with the welding wire moving through it , it will wear a groove in the liner that jams the wire as it moves through
Really evident if you change from a small gauge wire to a slightly larger wire
rust in the liner from wire that has not being used for a while will also cause the erratic feed
the fix is to clean the wire prior to going into the liner or replace the liner for both
Aug 06, 2015 | Welding Tools
Hp photojet 7520 automatic document feed works but is very noisy since I removed a paper jam.
one of the gears must have come out of place a little. Will still work but will be noisy
Feb 28, 2015 | HP PhotoSmart Office Equipment & Supplies
Air compressor slow to build pressure, and noisy.
All large air compressors are very noisy.
How long it takes to come up to pressure depends on the size of the compressor piston(s), how fast they are running and the size of the air tank attached to it. (and if the tank or hoses have leaks)
A 20 gallon tank could easily take 10 minutes to get all the way up to 120 psi. 120 is very high, and probably the limit for the compressor. Depending on what you're using it for, try dropping the setting to say 80-90psi.
Sep 25, 2012 | Air Tools & Compressors
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
When the dryer is turned on, it usually starts slow
Could just be the drive belt, or the motor starter is faulty.
Feb 22, 2010 | Dryers
Paper jams at front feed. noisy when starting. grinding noise
Run remove ink smears. Clean pick an feed rollers with packing tape.
Jul 27, 2009 | Xerox Phaser 8500/DN Printer
Extremely noisy fan!
First turn off your pc, pull out the main cooling fan and clean with with an oil or a wd-40.
Jan 15, 2009 | Computers & Internet
Fellowes Saturn 2 A3 Laminator Laminators Logo
29 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
