Question about Stanton T52 Turntable
Need a new belt
I bought a Stanton T52 Turntable, but I need the belt. I've done a few searches but haven't had much luck. Where can I find a belt replacement?
  • Stanton Master
  • 5,190 Answers
The best I can suggest is that you measure the diameter of the belt in mm and put that into google search with the words "turntable drive belt". Hopefully something should come up! I would suggest contacting Stanton, but I couldn't find the website for the company, so that might be a waste of time, but if you want to try have a go!
Posted on Mar 15, 2014
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: stanton turntable: STR8-30 need to
You look at the cartridge, determine its make/model number if visible and web search for that with 'replacement stylus'. There is no way we can tell what is installed on it.
Posted on Aug 07, 2011
SOURCE: Stanton STR8-100 Turntable ground wire?
i had the problem with stanton t92 solved it by plugging ac cord into receivers switched input
Posted on Aug 01, 2013
Stanton T52 turntable static
Tricky. I would suggest running a wire to a earth point such as a copper pipe, say of a radiator. A lot of static could be caused by yourself when handling an record. Some carpets make this worse. You can get an anti-static earth strap for yourself, when you handle the records.
http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_7?url=search-alias%3Delectronics&field-keywords=anti+static+wrist+strap&sprefix=Static+%2Caps%2C177
Feb 22, 2015 | Stanton T52 Turntable
Stanton T52 Turntable. I get intermittent, loud popping, like static. I have checked ground wire, and it is hooked up to receiver just fine. I have cleaned my LPs in every way possible and have tried 3...
There are 3 possibilities I believe here. First a faulty connection to the cartridge or the cartridge itself. (2) internal (inside the deck) fault on a pre-amp. (3) Fault on the magnetic cartridge pre-amp in your amplifier. This would not effect any other functions on the amp.
I bought a Stanton T.52 turntable, but I need a belt. I've done some searches but can't seem to find anything. Where can I buy a belt?
Stanton is a hell when it comes to parts, just via a dealer is the best solution. But have you first tried to get the grease and dirt of this belt? and offcourse the poulies (round metal or plastic it spins on)degreasen. Do you use a clampweight or so..? Kind of waste of money and don't forget that the motor in this pricerange ain't a strong one is, which spins at a perfect 33, the st.150 is also cheap built and if you go for the music quality i recommened pro-ject or rega. Those have nice beginner hifi tables with a way better arm for 400 euro's new and pro-ject has the option to upgrade it , by give them the arm you use and buy the more expensive/better one for way less. And those sound way better then a stanton. The needledoctor.com sells a lot gear http://www.needledoctor.com/Pro-Ject-Debut-Carbon-in-Light-Grey?sc=2&category=352. but this table comes included 2mred , which i also have, but your records needs to be real clean, so i use them seldom:). And i have checked the side where i sometimes buy vestax gear, but yours wasn't between them. Just go to a dealer and they get one for you or check ebay.
But first try to clean it well, a little oil on it and your grip is gone.
Goodluck, greetings richard
Feb 08, 2014 | Stanton T52 Turntable
Internal fuse
Unfortunately, there can be too many causes for this. For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 27, 2013 | Stanton T52 Turntable
Request no:173449ayaij
Have a look under the turntable to see if you can find a speed preset. You can adjust them with a screwdriver. They might be covered up with a sticker. Often there are two one for 33 and one for 45.
Feb 05, 2013 | Stanton T52 Turntable
Purchased stanton T.52 Turntable. hooked it up to stereo but volume is very very low. cannot find line / phono switch if there is one on this model.
The only output from the turntable is the low-level signal from the cartridge. Most likely, the receiver you've hooked it to doesn't have a phono input. Many receivers today don't come with one, and if you connect the turntable to a line-level input you get either very low volume or none at all, depending on the cartridge. What you'll need is a turntable preamp to boost the output to line level so the receiver will work properly. Radio Shack still carries a preamp, available online and in some stores. You can also find preamps online (here's one at Amazon). With the preamp connected you can use any free input on the receiver.
Jun 05, 2011 | Stanton T52 Turntable
Stanton Turntable Problem with receiver/audio
You need a turntable pre-amp, or a receiver with turntable inputs.. The turntable is functioning properly, until recently no turntable had this built-in. Search ebay for turntable pre-amp and you should be good.
Oct 04, 2009 | Audio Players & Recorders
Low audio
Make sure it's plugged into the PHONO section. There's a good reason they label it for that - only Phono requires PRE-amplification to boost the tiny signal from the cartridge to a suitable level for the following stages to use.
Apr 04, 2009 | Stanton T.90USB Turntable
Stanton T52 Turntable Logo
82 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
