Question about HP Officejet 4620 e-All-in-One Printer, Print / Copy / Scan / Fax, USB 2.0, Wi-F
Hp 4620 scanner does not work
Scanner does not work
SOURCE: Scanner won't work
hi,dahaka,
I did, but can't find the "Hp director" .
(start, all programs, HP) in "Hp" don't have Hp director!) where can find it?
bhca1704
Posted on Feb 05, 2008
jigsawbill
  • 398 Answers
SOURCE: hp 3030 scanner
Go to HP and download proper software, and drivers there is some scanner software in there to make scanner work.
Posted on Aug 04, 2008
jarifa
  • 30 Answers
SOURCE: hp 5610 scanner not working with vista home edition
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
748
Posted on Feb 27, 2009
  • 169 Answers
SOURCE: hp psc 1210 It says no scanner found ?
as the copier works its not a hardware concern.if the scanneris not found it means the drivers are not installed properly.Try uninstalling the drivers completely from the device manager as well as the printer and faxes and the scanners and cameras(if possible delete the ebtries in the registry as well that are related to the software and the VID and PID keys from there).Then try a plug and play.....see if it works....
Posted on Jun 24, 2009
SOURCE: Scanner won't operate on HP PSC1410 All in one with Leopard
I had the same exact problem and found this solution in a Mac forum. Download this set of drivers HP Photosmart, PSC and Officejet Full Feature Software/Drivers - Mac OS X v10.3 and v10.4 (Universal). My PSC works fine now.
Posted on Jul 21, 2009
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
MY HPOFFICEJET ALL IN ONE SERIES 4620 WILL NOT PRINT IN BLACK WHEN YOU DO A ALIGNMENT PAGE THERES NO BLACK WRITING SO THE SCANNER SAYS COULD NOT DETECT ALIGNMENT PAGE ALIGNMENT FAILED WHAT CAN I DO NEW...
I have a 4620, and had the same thing occur with the black ink. After a few hours on the phone with HP and them sending me a replacement printer that also wouldn't print, I found that there is a "vent" on the printer cartridges that if clogged, will cause that color not to print. The vent is on the top of the cartridge, facing up when installed into the printer. The vent looks like a "T". Unfortunately, the packaging that HP uses on these cartridges sometimes causes glue to clogged the vent. Take a sharp nail or straight pin, and clean out the vent. Hope this is successful for you.
Aug 01, 2014 | HP Office Equipment & Supplies
My HP screen says Scanner failed. Can I fix this/
no u can't fix it because ur scanner has a rode, i.e looking like a tublight when u scanned a document the rode move one direction to other direction, rode don't move on ur scanner, so ur hp screen says scanner failed, if ur printer is in warranty goto to service center , if out of warranty, open scanne glass cover and check light rode on the scanner, lightly try to move the rode and see is something
bump with this rode , fix it
Jun 26, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
Scanner software
Hey,
you can download or sometimes buy/order a new disc from hp from this page
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3423841&lang=en&cc=uk&prodTypeId=15179&prodSeriesId=3423840&taskId=135
just select the right windows version to get the drivers etc.
Let me know if you need anything else.
Thanks,
Ekse
Feb 26, 2009 | HP ScanJet 2400 Flatbed Scanner
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Hp 3030 scanner
Aug 04, 2008 | HP LaserJet 3030 All-In-One Printer
SCANNER DOESN'T WORK
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00803473&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
You can also attempt to reset the AIO:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00637484&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
For the Mac (possibly):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01396146&lc=en&cc=ca&dlc=en&product=1128296&rule=20851&lang=en
Jan 23, 2008 | HP DeskJet F380 All-In-One Printer
HP Officejet 4620 e-All-in-One Printer, Print / Copy / Scan / Fax, USB 2.0, Wi-F Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
