Question about Tunturi Exercise & Fitness
Ft94 treadmill error LSI
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Tip
I/O DEVICE DRIVERS WEBSITES AND INFORMATION
www.adlinktech.com/faq
www.linuxcertified.com/linuxtraining/open_source/
www.lsi.com/products/10-controllers/pages/lsi-sas-1068e.aspx/
www.vmwave.com/resources/compatibility/search.php?devicecategory=/
www.developer.apple.com/library/mac/documentation/devicedrivers/
www.windows.microsoft.com/en-us/update-driver-hardware-install-working-properly=windows-7/
www.tech-faq.com/io-device-error.html/
www2.advantech.com/products/i-o-drivers-and-utilities/
www.nirsoft.net/utils/driverview.html
www.docs.oasis-open.org/virtio/v10/csd01.html/
www.aja.com/en/products/io-4k/
www.jupiteri.com/ji4040_files/ji-4040_top.html
www.aja.com/en/products/io-xt/
www.maxtrox.com/video/avid/
www.kepware.com/products/products_opcservers.asp
www.en.wikipedia.org/wiki/device_manager/
www.support.hp.com/ie-en/document/c03540049/
www.pcidatabase.com/
www.phoenixcontent.com/online/portal/us?1dmyturile=wcm.path:/usen/web/main/product/subcategory_pages/drivers_and_interfaces_p-19-07/1429bca8-7058-491d-b8fb-7582775827cff08b5/
www.avid.force.com/pkb/articles/en-us/troubleshooting/en349411/
www.Im-sensors.org/wiki/devices/
www.tenasys.com/tenasys-products/intime-technology/
www.phidgets.com/
www.toolboxopc.com/html/drivers-list.asp/
www.opensourceforu.com/2011/i/o-control-in-linux/
www.trihedral.com/device-driver-list/
www.ibm.com/support/docview.wss?vid=ssg1s7000303andaid=1/
www.asp.anl.gov/epics/
www.siig.com/drivers/manuals/
http://www.tux.org/ikmi/ [linex mailing list]
www.openbsd.org/i386.html/
www.content.dell.com/_layouts/xdb.ashx?global:apps2:sdc:downloads/
www.sciencespaces.com/type/multifunctional-drivers/
www.blackmagicdesign.com/products/ultrastodiothunderbolt/
www.tutorialspoint.com/opering_system/os_services.htm/
www.protoolproduction.com/hardwaresetup/
www.mot.com/sps/power_pc/
http://www.studies.ac.upc.edu/doctorat/engrap/vxworks-device-drivers.htm/
www.pcsupport.about.com/od/driversites/tp/drive_download_websites.html/
www.7tutorial.com/finding-missing-drivers-hidden-componets-device-managers/
www.drivers.com/fix-install-dell-drivers.php/
www.developer.mbed.org/handbook/
www.unix.stackexchange.com/questions/97676/how-to-find-the-driver-module/
www.support.symantec.com/en-us/article.tech155178.html/
www.ftdichip.com/
www.zadig.akeo.ie/
www.vb-audio.apagesperso-orange.fr/cable/
www.ab.rockwellautomation.com/IO/
www.ozzu.com/hardware/device-error-t31209.html/
www.iogear.com/support/dm/
www.twain.org/scannerdriverdevelopers.html/
http://www.sane-project.org/
www.computerhope.com/i/o_drivers/ahardwre.htm/
www.pridopia.co.uk/rs-pi-set-scratch.html/
www.support.and.com/en-us/downloads/
www.perle.com/support_services/documentation_pdfs/5500029-15pdfs/
www.onsemi.com/i/o_drivers/
www.v-stahl.com/products-and-systems/remote-io-is-1.html/
www.sealevel.com/i/odrivers/
on May 14, 2015 | Computers & Internet
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
http://electro-medical.blogspot.com/
Mar 08, 2016 | Exercise & Fitness
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
Showing 121: fatal error
It is not exactly "fatal", it is related to LSI power supply or disturbance in it communication with high-voltage LSI chip, try this solution first:
1. switch off the printer and remove cord from power supply, remove network connection as well.
2. switch printer on (without power!) for 20sec, switch off
3. connect power supply, and switch printer on
4. connect network cable
If this operation did not clear the error, unfortunately you need to service the printer.
Hope this will help to solve your problem, please leavenote how did it go.
Aug 17, 2010 | OKI C5500n Laser Printer
DVD was working fine then display screen flashes ":LSI NG", help!
I actually got the same problem.
Did you succeeded to solve it ?
Jun 23, 2009 | Pioneer DVR-520H DVD Recorder
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Exercise & Fitness Logo
15 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
